mz rt 125 back brake ( gone )
Postby gjmzbiker » Thu Jul 09, 2009 8:02 am
any one now why the back brake just stops working.. then when you bleed it nothing happens the caliber empty's but the reserve is full .. the peddle has no pressure what so ever any ideas
gjmzbiker
Re: mz rt 125 back brake ( gone )
Postby Old Dog » Thu Jul 09, 2009 11:17 am
Sounds like your pump is shot
All the best
Old Dog
Old Dog
Postby robert mack » Fri Jul 10, 2009 10:50 am
i have the same problem. will be stripping the calliper in the next hour or so. have you tried changing the seals??
British by birth,Scottish by the grace of God.
robert mack
Postby DAVID THOMPSON » Fri Jul 10, 2009 10:00 pm
if the piston at the foot pedal is not retracted all the way when your foot is not on the pedal---
new fluid can not enter the system from the
Hydraulic Fluid Reservoir check pedal adjustment
and the rt125 is a hard one to get the AIR out of the system
Postby robert mack » Mon Jul 20, 2009 3:19 pm
it might help if you flush the system out with fresh fluid. ive been struggling for about a week to get good
pressure. flushed the system through(about 4 reservoirs worth) tightened up the bleed screw and presto! back brake is solid. :-D
and because your replacing the fluid, it gets all the air out.
robert mack
Postby robert mack » Tue Jul 21, 2009 11:34 am
have you changed the seals mate??
as i said above i had flushed it out last night.
checked it today and was soft again. changed the seals, bled the system to death and now its solid.
how is the calliper itself?.
if its scored on the inside then it can let fluid through
HTH :mrgreen:
robert mack
