Do SM tires have inner tubes or are they tubeless?
Postby herbalist » Fri Nov 25, 2005 10:55 am
I need to know ASAP.
Thank you.
herbalist
tube tubless tires tyres
Postby DAVID THOMPSON » Fri Nov 25, 2005 1:19 pm
if your bike has spoke wheels like bikes from the old days
tubes are required
there is a bmw model with spokes to the outside of the rim edge that will do tubless
if it is one with alloy rims look at the valve stem where you put air in tire
if it has a nut holding it in it is tube if stem is like car stem it is tubless
be carefull some alloy rims need tubes my 1995 MZ SAXON TOUR has alloy wheels but needs tubes :-D
Postby jbthumper » Fri Nov 25, 2005 2:06 pm
SM got tubes?? = Yes. :-)
:smt033
jbthumper
Postby herbalist » Fri Nov 25, 2005 3:11 pm
thanks guys,
Had a flat tire this morning.
Took it to the garage pumped it up to 26psi, the thing went down to 18.5 in less than a minute.
After further inspection it looks like the leak is coming from the valve.
(nothing sticking out of the tire)
I have since picked up a vavle key and some gel that you put in the tires to protect against puntures.
The guy in the shop asked if I had spokes on the wheel.
(because the gel only works with inner tubes.)
Then sold me the gel (which included a vavle key.)
So unless you have a reason, tomorrow Im gonna tighten the "valve core."
If that stops the leak. (i.e. no faulty vavle core)
Im gonna put the gel in the tires and job done.
herbalist
sx tubes
Postby DAVID THOMPSON » Fri Nov 25, 2005 4:34 pm
if i remember you just converted from bicycles to motor cycles
the tires changes the same way there just harder to break from the rim
and work with... i am inclined to see what is leaking and if its the tube
replace it ....but doo check tire for what caused the leak it may still be in the tire
take a flash lamp and look inside for nails or other stuff
if the old tube is patchable do so and keep as a road spair for that day
you go flat and there are no shops open to buy one
parts book lists rear size as rear as 120/80-18
front 90/90-21 front thats for sx model
i am not a fan of the fix a flat spray cans
Postby herbalist » Sat Nov 26, 2005 10:11 am
Looks like a faulty vavle core.
Gonna go to a shop and get them to replace it.
And youre right about the gel stuff, no good for the rims.
I wont be using that.
herbalist
Postby Drew » Mon Nov 28, 2005 2:11 am
Valve cores are cheap, and easy to replace yourself. A valve core tool will set you back ~$3, and is a wonderful addition to the toolbox. Most likely the shop didn't tighten the core all the way; it happened to me once coming from the shop on my sportbike.
Relax. You'll live longer.
Drew
