yodamac wrote:Update: I got the bike to start after opening the drain on the carb, but it wants to run with the starter carb at the first click. It's almost like it's starved for fuel without the choke (started carb). Also, it doesn't run steady, it revs from 3000rpm to 5000rpm every 5-10 sec. It will die fast if I take the starter carb off (choke equivalent) unless I give it gas. I can baby it down to 2000 rpm if I'm careful but it almost immediately dies if I try to hold it there. I tried adjusting the idle screw (the one with the spring and grip on the outside). I went from fully closed to open 1.5 turns to 2 turns and out but it doesn't seem to make a difference. My understanding is this should idle around 1400-1500 rpm. Any advice on getting it there?
