jbthumper wrote:OK. That's it!!!I give up!!
my carb doesn't pull well underload...apparently my carb that doesn't have an air mix adjuster,spells trouble.
sure it can idle well...so what...
i feel like the carb gives my bike too much of everything...air and fuel...
so i've decided to scrap the project.....(sigh)
i guess it'd only work on 2 strokes...
But can't say anything about the one sold on the net though...because it's different..
next project
125EFi
mxsteven wrote:well at first my bike had the same idling problem too... so at last i found out it is the exhaust... so now i replace the whole system to Answer S11 system... Next month wanna 2 try the super trapp coz this answer exhaust is quite noisy.. and i found out 2nd thing, do u notice that when u pull ur handle to ur right while u idling then ur idle goes unstable...? Thats the throttle cable problem... i rearrange the cable but still sometime happen again... arrggghhh.... i just ignore the problem which is rev and go heheheh..
p/s:i'm using supertrapp...if you want quiet,this is definitely not it.
iskarin wrote:p/s:i'm using supertrapp...if you want quiet,this is definitely not it.
JB n MXsteven any plc in KL can get a good exhaust? JB do u get ur supertrapp locally or over the net (Is it from S'pore) Give some recommendation guys planning to get one next week.
BakBer wrote:somebody jump in here and tell me were to get the 150cc kit... You guys need the
BakBer wrote:Well...I do need to replace my rings so yes I need it. LOL! I'm in The US but I'm willing to pay shipping depending on the price of the kit. I can have my cylinder machined locally if the kit is only a piston.
What kind of power increase did you see when you did your kit?
Thanks for coming on here. I was going to try and Email you b/c it didn't look like you had been on here for a while.
mxsteven wrote:BakBer wrote:Well...I do need to replace my rings so yes I need it. LOL! I'm in The US but I'm willing to pay shipping depending on the price of the kit. I can have my cylinder machined locally if the kit is only a piston.
I can ship you the piston and stuff but you will need to rebore your piston block and mod the slinder water jacket for a better cooling.
the power increment was dramatic which it produce the power equivalent to Honda XR200 coz i have tested! The torque improves a lot!
i have even tried to make the stroke longer which increase up to 178cc but the starter cant crank due to higher compression! now i balance my crankshaft
back to standard mod!
The piston and the rings is very cheap here! let me get back to you with the pricing! i think i will ship to you 2 sets hahaha
i done all my mods less than 300USD including labour charges for boring and machinery stuff!
Users browsing this forum: No registered users and 233 guests
