Jamie wrote:I am sure i have read somewhere that there was a factory modification of the addition of a zip tie under the tank.
I will see if i can find that as well.
Jamie
OSPRNG wrote:i have completely disconnected the throttle and choke cables and routed them the best way imaginable (tried about a dozen different paths and reassmbled the bike each time for a full test).
none of them did anything better. i'm starting to wonder that maybe routing is only half of the problem here, and maybe some reasonable movement in the cable is being exagerated by something else in the scheme of things.
i cant imagine Jamies pictires providing a path other than one of what i have alreday tried, but heres to hoping.
no mechanic in the area is willing to take a look at this ("MZ? who the heck makes them?")
borisattva wrote:you mentioned you had to adjust the throttle cable by the grip to get it to start.
maybe it is now too tight. try loosening it up and see if the revs change with the handle bar movement.
if they dont, try adjusting the idle screw instead of the throttle nut to deal with the starting issue.
