125 SM rear brake seals.
Postby keithcross » Sun May 07, 2006 4:07 pm
While working on my sons 125 SM today, I had to take the rear caliper apart as it was all siezed up. Also looked at the seals. They looked a bit rough, so I removed them and thought they looked familiar. I work on Goldwings quite a lot and checked against some seals I had in stock discovered the seals are the same as those fitted to one of the Goldwing 1500 front calipers.
Got to be easier than waiting for MZ :)
Honda part number 06451-GE2-405.
This part number give a dust seal and hydrulic seal, so 2 sets needed for the caliper.
With a bit of luck this may help some of teh posters here.
rear
Postby DAVID THOMPSON » Sun May 07, 2006 9:59 pm
if this works on the rear on sm it should work on the other
125cc bikes on the rear
i am now checking mz parts books to see if front seal numbers
are same as rear numbers
the rear pads are ebc fa197 or kawasaki 43082-1238
my bike is hard on these pads check them often
and i am not a fan of using the rear brakes too much or hard
and i do in a set in 4000 miles (6437km)
rt125brakesealseal
Return to 125 cc
