plz help, need sm125 parts
Postby ginger steve » Tue May 20, 2008 9:20 am
anyone know where i can get my hands on a few bits, need a headlight unit, ignition barrel and key and fairings, cheers
ginger steve
Re: plz help, need sm125 parts
Postby DAVID THOMPSON » Tue May 20, 2008 9:39 am
http://www.grahamsmotorcycles.com/
parts book is on line on the site they ship world wide
update your profile to include your city and country
Postby sputera » Tue May 20, 2008 11:44 pm
I can find it for you in Malaysia, but not sure how much the cost of shipping....
sputera
Postby cucudatok » Fri Jun 13, 2008 11:58 pm
I just bought 125sm, a month ago. Now facing water pump leaking problem. Can the seal be change, or need to change the complete set?
Is there any subtitute from other model/make? Please help. Thank you in advance.
cucudatok
Postby DAVID THOMPSON » Sat Jun 14, 2008 9:45 pm
LINK IN ABOVE POSTS TO PARTS BOOK
ALSO DROP THIS PART NUMBER IN TO A GOOGLE SEARCH
9015068000
PUMP PLUS 2 O RINGS MAY BE SIMPLE OR HARD
DAVE
NOT HARD TO GET AT JUST MESSY AND TIME CONSUMING
Postby cucudatok » Mon Jun 16, 2008 6:28 am
Actually I have the part list for MZ125SM, but right now it is quite hard to get the parts in Malaysia. Now I keep riding the bike in this condition. It has been 7000KM. Is it very bad for the engine if I keep on riding with out changing the part? Or can I just change the oil more often? Please advise. Thanx.
cucudatok
Postby DAVID THOMPSON » Mon Jun 16, 2008 8:51 am
if water is leaking into the oil STOP
there is a weep hole in bottom of motor right front
is it leaking oil ...water or both
there are 2 seals on pump main shaft
if there bad you should get drain from bottom of motor
if you have water in the oil you most likely have a bad gasket some where like head or base gasket
Postby ginger steve » Sun Jul 06, 2008 5:43 am
the overflow on my sm 125 radiator is always leaking water, i was told to remove the thermostat but it keeps doing it, any ideas?
cheers
ginger steve
Postby DAVID THOMPSON » Sun Jul 06, 2008 11:03 am
try a new cap and check water level when hot but be careful
there may be too much water in it to start with ...when hot it expands and comes out because there is no room inside
Return to 125 cc
Users browsing this forum: Google [Bot] and 8 guests
