Hand Gaurds
PostPosted: Fri Sep 09, 2005 7:02 am
by blackpantheruk
Anyone know what hand gaurds will fit straight onto the Black Panther?
trying to find some on t'internet.
i like the gaurds that cover your whole hand and connect to the bar end,
Cheers,
Craig
PostPosted: Fri Sep 09, 2005 1:02 pm
by BRAAAP !
I've just bought some of eBay. .
check out item #4574270178 on ebay.co.uk
cheap end of the market but don't look like a pair of moose ears !
not fitted mine yet but dusne look to difficult . . . .
PostPosted: Fri Sep 09, 2005 4:03 pm
by roge-a-billy
Got some to of Evil bay. I'm going to have to either buy shorter / different levers or cut the ends off and get replacement ones to fit for M.O.T time. Also crash bungs for the wheel spindles, the spindles seem to be solid right the way through, so will have to put a thread in them with long bolts :roll:
PostPosted: Fri Sep 09, 2005 4:21 pm
by BRAAAP !
going to get my MOT before fitting them. . .
seen a lot of folks that seem to angle the guards down to avoid this problem. . .
anyone got any ideas regarding fitting brush guards ???
:smt102
PostPosted: Fri Sep 09, 2005 8:30 pm
by phlat65
trimming the levers, or wider bars so you can move the clutch and brake in to clear. I run bark busters on the RM , and never have to cut levers, but on the baggy, I had to remove 1 inch or so.
I run the MSR guards, and they have lived through an asphalt crash with minor scratching.
PostPosted: Sat Sep 10, 2005 3:31 am
by bigzed
I'm using acerbis guards,not the bark buster ones though, which went straight on to renthal bars with no cutting of levers or messing about.
PostPosted: Sat Sep 10, 2005 6:16 am
by blackpantheruk
where do i get renthal bars? are these better than the stock?
Cheers,
PostPosted: Sat Sep 10, 2005 10:51 am
by bigzed
Hi craig,Try bandcexpress , demon tweeks or google for a local dealer, i don't know if they're any better than stock but hey bling is bling
PostPosted: Sat Sep 10, 2005 10:58 am
by blackpantheruk
what size do i get?
cheers
PostPosted: Sat Sep 10, 2005 2:02 pm
by bigzed
http://www.bandcexpress.co.uk/cgi-bin/b ... FROAD&nav={universal}
Hi,i would say any of the top two, although others here might be able to suggest otherwise through experience with different types.
aw the best
Gaz
PostPosted: Sat Sep 10, 2005 2:03 pm
by bigzed
aw the best
Gaz
PostPosted: Sat Sep 10, 2005 9:25 pm
by phlat65
size and bend are all preference. the CR high, and CR low are the 2 most common bends. I think I run a doug henry bend pro-taper, they are pretty straight with little pull back.
