by Retired1 » Fri Nov 09, 2018 12:24 am
Was working on my new to me '02 skorpion traveler, tried to bump up the spring preload and lo and behold! The spring adjuster collar has split! I suspect riding it will result in a sudden ride height reduction. Anyone have a decent shock lying around or what is the latest compatible replacement? I seem to have read the R6 will bolt in directly, is a spring change in order? any help would be greatly appreciated.
Retired1
by Retired1 » Fri Nov 09, 2018 3:58 pm
Crisis delayed! I made a tool to compress the spring enough to unload the adjuster ring and welded it back together, along with tacking it to the shock body. adjustability is overrated anyway!
Retired1
by ironhorse99 » Sat Dec 14, 2019 9:55 pm
I see its been quite a while since yr last post & just wanted to mention what I did when my rear shock failed on my 01 traveller. I bought a Hagon shock. Way more robust in every way & adjustable too. Model HA M67080. Cost U.S. $394.00
ironhorse99
