Skorpion wiring diagram
PostPosted: Wed May 23, 2018 3:48 am
by Hooperman999
Where can I get a wring diagram for the Skorpion?
Re: Skorpion wiring diagram
PostPosted: Wed May 23, 2018 7:09 am
by dickl
PM me with your address and I'll send you a photocopy - which model have you got?
Dickl
PostPosted: Wed May 23, 2018 10:52 am
by lavrentyuk
Given some of my wiring hassles recently if you have one could I ask for a copy please - a scan would do marvelously.
I have a Skorpion Sport, 2001.
I have never seen a wiring diagram for one and have been making it up as I go along. Fortunately they are fairly straightforward.
Richard
PostPosted: Wed May 23, 2018 11:50 am
by Guesi
Here is a wiring diagram:
Schaltplan_Skorpion_98.pdf
(964.41 KiB) Downloaded 1053 times
PostPosted: Wed May 23, 2018 2:42 pm
by lavrentyuk
Thank you.
PostPosted: Thu May 24, 2018 8:33 pm
by DAVID THOMPSON
CLICK ON PIC TO MAKE IT BIGGER
relay 19 carrys it all
PostPosted: Fri May 25, 2018 5:59 am
by edfmaniac
Note: This is for the Baggy. Probably going to differ from the Skorpion diagram. :)
PostPosted: Fri May 25, 2018 6:07 am
by edfmaniac
Here's one from an old thread on this site called "Wiring Diagram". I found it by Googling "mz skorpion wiring schematic". ;)
PostPosted: Fri May 25, 2018 9:33 am
by DAVID THOMPSON
the main relay number is different rt125 drawings calls it 19 some 660 drawigs call it 30 others call it 21
it carries all the current and is not big enough over time so it dies
21 on above is the spark coil
and the drawings are reversed sides look where the tail lamps are on the two drawings
my rt125 had it fried in the first year the traveller was sick when i got it rotax 500 does not have one or a side stand switch
