Skorpion wiring diagram
Postby Hooperman999 » Wed May 23, 2018 3:48 am
Where can I get a wring diagram for the Skorpion?
Hooperman999
Re: Skorpion wiring diagram
Postby dickl » Wed May 23, 2018 7:09 am
PM me with your address and I'll send you a photocopy - which model have you got?
Dickl
dickl
Postby lavrentyuk » Wed May 23, 2018 10:52 am
Given some of my wiring hassles recently if you have one could I ask for a copy please - a scan would do marvelously.
I have a Skorpion Sport, 2001.
I have never seen a wiring diagram for one and have been making it up as I go along. Fortunately they are fairly straightforward.
Richard
Richard Marshall
Wales, U.K.
lavrentyuk
Postby Guesi » Wed May 23, 2018 11:50 am
Here is a wiring diagram:
Schaltplan_Skorpion_98.pdf
(964.41 KiB) Downloaded 1053 times
Guesi Motorradteile
MZ spare parts
Postby lavrentyuk » Wed May 23, 2018 2:42 pm
Thank you.
Richard Marshall
Wales, U.K.
lavrentyuk
Postby DAVID THOMPSON » Thu May 24, 2018 8:33 pm
CLICK ON PIC TO MAKE IT BIGGER
relay 19 carrys it all
Postby edfmaniac » Fri May 25, 2018 5:59 am
Note: This is for the Baggy. Probably going to differ from the Skorpion diagram. :)
Postby edfmaniac » Fri May 25, 2018 6:07 am
Here's one from an old thread on this site called "Wiring Diagram". I found it by Googling "mz skorpion wiring schematic". ;)
Postby DAVID THOMPSON » Fri May 25, 2018 9:33 am
the main relay number is different rt125 drawings calls it 19 some 660 drawigs call it 30 others call it 21
it carries all the current and is not big enough over time so it dies
21 on above is the spark coil
and the drawings are reversed sides look where the tail lamps are on the two drawings
my rt125 had it fried in the first year the traveller was sick when i got it rotax 500 does not have one or a side stand switch
Users browsing this forum: Google [Bot] and 31 guests
