Page 1 of 2
Skorpion Traveller
PostPosted: Sun Jan 14, 2018 10:10 am
by manxie
I sold my Skorpion Sport because I couldn`t get on with the riding position and to be truthful, was a bit of a dog. However, apart from the riding position I loved the bike.
So today I went out and bought a 2000 Skorpion Traveller. All original except indicators (originals with the bike) in lovely condition and also comes with the original panniers. I`m taking delivery of it next week end and just looking forward to some dry warm weather now :( :(
:D :D :D :D :D :D :D
Re: Skorpion Traveller
PostPosted: Sun Jan 14, 2018 2:53 pm
by edfmaniac
Nice. Do yourself a favor, open up the airbox by removing the snorkle and rejet the bike. You'll immediately change the character of the power delivery. Stock main jets are too rich and the pilot jet is too lean, which sometimes causes it to be hard to start cold.
PostPosted: Sun Jan 14, 2018 3:08 pm
by manxie
I`ll take a look at that, thanks for the info. What size jets do you recommend :wink:
PostPosted: Sun Jan 14, 2018 8:12 pm
by edfmaniac
manxie wrote:I`ll take a look at that, thanks for the info. What size jets do you recommend :wink:
Keihin 135 and 155 for the mains and a Mikuni TM28/486 #40 or #38 on the pilot
PostPosted: Mon Jan 15, 2018 3:14 am
by manxie
THANK YOU ;-)
PostPosted: Wed Jan 17, 2018 3:12 am
by breakwellmz
Hi
How do the (later) Mastiff/Baghira compare main jet wise? I know they have too small a pilot jet but did they put more suitable main jets in them?
It seems odd that a manufacturer could get it so wrong. :roll:
PostPosted: Wed Jan 17, 2018 10:53 am
by edfmaniac
Probably the same treatment for the other 660 models. Do they have the fuel pump that all of the Skorpion owners are supposed to immediately take off?
I think the jetting issue was pretty common in a certain era of bikes. Lean on the bottom for emissions tests, and fat on the top so the average rider could put a lifetime of riding on the bike safely, at nearly any altitude, without having to rejet it. The jets I recommended would probably be too lean in colder, high altitude settings, but really wake the bike up here at 500ft sea level and 69.4F on average.
FYI Almost every bike ever produced is leaving horsepower on the factory floor for one reason or another. You just have to do a little research for your model then put in some work, or pay someone, to uncork it. Pulling airbox snorkles or venting the airbox, matching carb boots to intake, rejetting, grinding restrictive header welds, and aftermarket performance exhausts are all things people usually do to unleash potential hp without needing a degree in high performance tuning.
PostPosted: Wed Jan 17, 2018 10:54 am
by DAVID THOMPSON
they had help from the smog testers that have never rode a bike
PostPosted: Thu Jan 18, 2018 8:18 am
by breakwellmz
edfmaniac wrote:Probably the same treatment for the other 660 models. Do they have the fuel pump that all of the Skorpion owners are supposed to immediately take off?
Hi
That`s interesting.I suppose for an emissions test the engine is not under load so you will not get off the pilot jet.
In terms of hidden power i know what you mean.After seeing a virgin-snow-white plug colour and poor running on the Puzey ( viewtopic.php?f=19&t=8821&hilit=+puzey ) initially i`ve gone richer on the main jet from 125 to 135 and raised the needle 3 notches, the difference is amazing!
The Puzey is South African and i think the jetting it came with was suited to high altitude and a hot climate, nothing like near sea level and the current cold damp climate here in the UK.
The Mastiff does not have have a fuel pump.
Cheers
PostPosted: Thu Feb 08, 2018 11:38 am
by breakwellmz
Hi.
Took the carbs off the Mastiff today.
Main jets are 130 and 165 respectively and i`ve got a 37.5 pilot jet to go in.
I think i will leave the 130(Although i have an appropriate size drill to take it to 135 thinking on it) and drop down to down to 155 on the Mikuni, any thoughts?
We don`t really do altitude here in the UK! :wink:
Cheers.
PostPosted: Thu Feb 08, 2018 8:33 pm
by edfmaniac
Just for clarity, there are no Mikuni carbs. Factory carb is a Teikei, but the jets are hard to find in the US, so I use Keihin main jets for the slide carb and the CV carb, and Mikuni for the pilot. It's just what I had available. If you have the same model pilot jet that I recommended but a #37.5 instead of a #38 or #40, you might have the same problems as the stock jet, having to run the mixture screw too far out. I'd run the #38 or larger. As for the mains, you could probably get away with 130/155. Just check the plug to make sure it isn't too lean.
PostPosted: Fri Feb 09, 2018 3:30 am
by breakwellmz
Hi
Thanks for that.Yes, Teikei not Keihin :oops:
Teikei jets are hard to find here but so are the Keihin 1001-806 type ones that are fitted.(I`ve only found one uk source but loads in the USA)
http://www.allensperformance.co.uk/carb ... ion-chart/
At the time a 37.5 pilot jet was the largest i could find but having looked again this morning i see i can now get a 40.(The supplier appears to show steps as being 2.5)-
https://www.ebay.co.uk/itm/EBC-Mikuni-C ... hf4COBWY4A
Compared to the Puzey where i can change a jet in a few minutes, i feel there is more emphasis on getting the right jets in the MZ first time because it`s so much more of a pain to get the carb off!
The plug has always looked lean but that could be down to the small pilot jet, the exhaust end has always looked rich.
What i would really like to achieve is a much lighter throttle action, but i think with all the mechanism involved that is unlikely. :(
Thanks again edfmaniac.
Cheers.
PostPosted: Fri Feb 09, 2018 4:30 am
by Skorpion
breakwellmz wrote:Hi
Cheers.
Will this help they seem to have a good selection of jets.
http://www.nrp-carbs.co.uk/shop/index.p ... ommon/home
PostPosted: Fri Feb 09, 2018 11:41 am
by edfmaniac
Try jetsrus.com. They should have everything.
A smooth throttle can be had with fresh cables. I put a throttle grip on my bike that had a shorter throw too. Can't remember which bike it came from though, and it wasn't a direct fit. I had to do some Dremel work to get it to work, but it reduced throw by quite a bit.
PostPosted: Sat Feb 10, 2018 4:56 am
by breakwellmz
Thanks for that Scorpian but the company i referred to have since got back to say they can supply what i want. :D
Edfmaniac-I thought of changing my throttle twistgrip to a single cable 90 degree trials type but can`t decide whether a slow or fast action will give me a lighter action, any thoughts anyone? I`m spoil`t by my other bikes really light throttle action, but then it`s only pulling a single slide against a light coiled spring.
Cheers
