Skorpion Lost Total Electrical Power.....
Postby jaywillie2912 » Fri May 19, 2017 7:01 pm
Battery still has 12 volts plus. Where should I start......
jaywillie2912
Re: Skorpion Lost Total Electrical Power.....
Postby dickl » Sat May 20, 2017 4:26 am
Fuses? Located under the seat - the rider's pad if you have a sport. Take off the pillion pad and there is a pull cord to release the front pad. Have you checked/tested the battery off the bike just to be sure, and the battery connections for connection and that the battery is on the right way round in terms of earthing?
dickl
dickl
Postby jaywillie2912 » Sat May 20, 2017 11:44 am
Researched problem, no juice - 15A fuse...........no blinkers - 5A fuse.
Replaced fuse - running fine.
I hope this helps someone.
jaywillie2912
Postby DAVID THOMPSON » Sat May 20, 2017 8:58 pm
had a lot of old bad fuses of late in bikes and two way radios
find what your bike uses and put some in a small plastic bottle under the seat with a tiny led flash lamp
nothing like being stranded in the dark
and a regular check of the battery
