petcock
petcock
Postby den » Sat Mar 11, 2017 1:44 pm
Hi friends of an MZ nature,,Does anyone know the distance between the hole centers of the standard factory fitted petcock on a baggy/mastiff.
den
Re: petcock
Postby DAVID THOMPSON » Sat Mar 11, 2017 3:15 pm
the rt125 is 12 mm center to center
i think all are same on mz plastic tanks
acerbis gastank petcock
acerbis numbers
left side 2044230999 points to rear when mounted on left
right side 2044230998
fuel proof o-ring needed and metric bolts the new bolt that come with it are wrong type thread
ktm dealer or husky probably has them
Re: petcock
Postby den » Sun Mar 12, 2017 9:39 am
mz baghira petcock fixing holes center to center ,on mine im seeing nearly 40mm and uprated aftermarket online (fleabay) im seeing 34mm centers..dont wanna order if im wrong
den
Re: petcock
Postby Dicer » Mon Mar 13, 2017 1:29 pm
I have a Skorpion Tour tank here (maybe different though) and the petcock fixing hole centers are 34mm for 5mm screws. The centre hole is about 10mm.
Clive in Central Florida
'96 Skorpion Tour.
Dicer
