Loony toons
Loony toons
Postby dandywarhol » Tue Nov 15, 2016 1:10 pm
Hi All - just got another SZR660 unfinished project with a 727cc motor, stage 3 Hotcam, Kibblewhite valves, guides, springs, Carillo rod, Projection Components downpipes, FCR35s, Ignitech unit. The chassis has a double disc Brembo front end so it's going to be a busy winter rebuild :lol:
Whale oil beef hooked
dandywarhol
Re: Loony toons
Postby edfmaniac » Wed Nov 16, 2016 5:09 pm
Should be a fun ride when you are done.
Re: Loony toons
Postby dandywarhol » Mon Nov 28, 2016 6:56 pm
I'm undecided whether to finish this or put the motor into my stock SZR660
dandywarhol
Re: Loony toons
Postby edfmaniac » Mon Nov 28, 2016 7:17 pm
Depends on how much weight you can cut in my opinion. If the project bike is 50lbs lighter, I'd vote to finish the project. You don't need those dual front rotors either unless you are some kinda top level rider and want to do track days with the bike. ;) Ditch one rotor and one caliper and include that in your weight calculations.
Re: Loony toons
Postby dandywarhol » Tue Nov 29, 2016 8:12 am
edfmaniac wrote:Depends on how much weight you can cut in my opinion. If the project bike is 50lbs lighter, I'd vote to finish the project. You don't need those dual front rotors either unless you are some kinda top level rider and want to do track days with the bike. ;) Ditch one rotor and one caliper and include that in your weight calculations.
Certainly not a top level rider but might be able to get some more on the anchors with 2 discs 8) Turn the sound low - it's crappy - also need to mount the camera off the fairing mount - the single cylinder frequencies and SJ CAM frame rate clash :lol:
https://www.youtube.com/watch?v=Xyg-upQZ_Qo&t=42s
dandywarhol
Re: Loony toons
Postby breakwellmz » Tue Nov 29, 2016 11:12 am
Enjoyed your video. :)
Re: Loony toons
Postby dandywarhol » Tue Nov 29, 2016 1:38 pm
breakwellmz wrote:Enjoyed your video. :)
Thank you :D
dandywarhol
