Replacement Stator
Replacement Stator
Postby roachdogg28 » Sat Sep 17, 2016 1:08 pm
So I put a couple miles on this bike since the purchase and since cleaning up the rough running condition which I posted about a couple weeks ago.
So she broke down when filling up and would not start, no charge...
Fuses looked good, battery was new, and just check the stator coil resistance and I'm seeing 8 ohms. The engine manual I'm looking at says it should be between .2-.3 ohms, so i'm looking for a replacement now.
My question is can I order a stator for a XT600? I don't want to wait for an overseas shipment and I want a reliable brand(hopefully better than OE). I found a rmstator for the xt600 for 99$. Just need to confirm i will fit up to my mastiff.
Thanks.
roachdogg28
Re: Replacement Stator
Postby roachdogg28 » Fri Sep 23, 2016 11:18 am
Well I charged my battery and apparently there's an internal short in it. It's brand new... Return time.
I threw in my spare to check a few things, and the charging voltage is 14.9V at 5K rpms, which matches what the manual states.
Even though my stator winding is out of spec by far, the voltage regulator still can work with it. I think I should still keep an eye out for a replacement stator, anyone have any thoughts on this?
roachdogg28
Postby edfmaniac » Fri Sep 23, 2016 2:49 pm
How did you check the stator? That number in the manual is for each field. You should have three numbers for stator resistance.
Postby roachdogg28 » Sat Sep 24, 2016 12:49 pm
Yes I check between all three wires, they were all +- .2 ohms of each other averaging about 8.
roachdogg28
Postby edfmaniac » Sat Sep 24, 2016 9:39 pm
You might want to check with a pro before replacing. I think it's odd that they are all off that far, and by the same amount.
Postby DAVID THOMPSON » Sat Sep 24, 2016 10:29 pm
use a good fluke meter
some of the cheap ones are not to accurate
and dont forget the leads if long or poor quality at very low values can mess up a reading
short the leads on meter and see what it reads and subtract it from reading
i some times do strange things with electric
but its been a long time since i made smoke come out of anything :smt040 :smt023
Users browsing this forum: No registered users and 47 guests
