95 skorpion sport carburetor lines hookup
Postby Marcum02 » Sat Jul 30, 2016 10:49 pm
Just bought a 95 skorpion sport 660 the carburetor was removed to be cleaned before I got it. When it was put back on, none of the hoses were reconnected and I can't seem to find a diagram online to show where they all connect to. Does anyone have a diagram of where all these lines connect ? Thanks
Marcum02
Re: 95 skorpion sport carburetor lines hookup
Postby OLDMTNCARVER » Sun Jul 31, 2016 9:56 am
Found these...
Vacuum lines.JPG (38.8 KiB) Viewed 3558 times
Hoses 7 and 9.JPG (36.68 KiB) Viewed 3558 times
OMC
OLDMTNCARVER
Postby OLDMTNCARVER » Sun Jul 31, 2016 10:09 am
I tried to click on the pictures posted above but had no luck enlarging them.
If you do a search [vacuum lines] you will see the same pictures.
Scroll past the first two posted and onto to the second set. I found that the second set of pictures can be enlarged.
Hope this helps
OLDMTNCARVER
Postby Marcum02 » Sun Jul 31, 2016 1:59 pm
Thank you for the diagram. It looks like there is two lines from the air box in this picture but on my air box I only have one connection for a hose. Do you know what I may be missing?
Marcum02
Postby DAVID THOMPSON » Sun Jul 31, 2016 8:30 pm
i an working on getting mine running
will try to get some good pictures this week of carb plumbing
it is a 97 traveller
Postby Marcum02 » Sun Jul 31, 2016 10:13 pm
Awesome thank you!
Marcum02
