Baghira rear turn signal replacements found, cheap.
Postby Rustyhub » Tue May 24, 2016 9:51 pm
These look to be the same exact thing. Not bad for $30 for the pair. I ordered them, so I'll find out first hand. Baja Designs Turn Signal Kit 60-4190 http://www.amazon.com/Baja-Designs-Turn ... C5XRRCX4P2
****update**** NOT THE SAME! I think I can get them to work, but they differ in the mounting bolt size (smaller than original) and do not have the anti-rotation protrusion in front of the mounting bolt.
****installed**** I had to use a rubber grommet I sliced in half to give the same effect as a step down washer since the mounting stem was@ 3/8 vs the original @1/2 (they are metric, of course). I used the existing wires. I would highly doubt they are made in Italy as the package states as the only part that will interchange with the original EIE made unit is the lens. Everything else is different.
Rustyhub
Users browsing this forum: Bing [Bot] and 78 guests
