Puff of dark smoke from exhaust?
Postby Petrolhead » Sun Apr 24, 2016 2:16 pm
When I have the Sport on its stand and its warmed up, a blip on the throttle and then snapping it shut to enjoy that lovely single blat blat, I get a puff off dark smoke from the can. :cry: Is this something to worry about or is it normal. I did wind the pilot screw out about 7-8 turns.
It does not smoke at any other time.....I was wondering if it was due to such a large piston drawing up oil when the carb slides are closed due to the large vacuum, is that logical?
Petrolhead
Re: Puff of dark smoke from exhaust?
Postby mincehead » Sun Apr 24, 2016 2:42 pm
Oil usually burns a misty blue, dark / black smoke is indicative of a rich mixture. :wink:
mincehead
Postby dandywarhol » Sun Apr 24, 2016 5:39 pm
Why did you wind out the mixture screw so rich? 5 turns further in might sort your problem.......................
Whale oil beef hooked
dandywarhol
Postby DAVID THOMPSON » Sun Apr 24, 2016 8:32 pm
these bikes are bad about backfiring on overrun
and some have found that 4 to 6 turn out helps bring it to a level where it can be lived with,,
my ideal is get rid of the cv carb for some thing else
i rode BMW from 1969 to 1999 and still have some
the bing cv on the r75/5 i had need to be pitched in the junk behind the shed
the r90s i owned for 28 years had a dell'orto and was a winner
cv,s will work but finding some one that can work out the bugs is not worth the effort
the big problem is the gasoline is CRAP
Postby Petrolhead » Mon Apr 25, 2016 10:48 am
It was the back firing and popping on a sharply closed throttle on the over run which made me turn the screw out so much. I got out to the garage and turned it in to 3 1/2 turns , it still runs OK on the stand, a bit less easy on the tick over so I had to turn the tick over screw in.....the tick over was best when it was out further though
But the black smoke is almost eliminated on blipping the throttle, just a whiff of vapour and the end of the can is dry , so a result there, thanks all :lol:
Petrolhead
Postby dandywarhol » Mon Apr 25, 2016 2:49 pm
There's a diaphragm on the side of the CV carb which is designed to stop the overrun popping. If it has perished, you need to adjust the mixture screw to compensate for a weakness caused by the diaphragm. Worth a look, especially with ethanol in the fuel
dandywarhol
Postby Petrolhead » Tue Apr 26, 2016 12:59 pm
Thanks for the tip, as we both know its freezing in Scotland just now so i'll wait for the weather to get warmer before I go for a roadtest. :roll:
Petrolhead
Users browsing this forum: Bing [Bot], Google [Bot] and 140 guests
