Bike has only covered 2400km is as new, has anyone had this and what sort of fix can I do?
dandywarhol wrote:If the top bush is metalastic then do the final tightening up with your weight on the bike - otherwise the bush gets a harder time on full compression.
Petrolhead wrote:Just a word of caution, the steel inner sleeve of the metalastic bush is bonded/vulcanised to it and the rubber shreds when you try and press it out.
