No Spark
Looking for other with similar problem = solution. Last early winter when I started my Baghira it got up to temp and started sputtering and died. Next day did same, since then not a hint of starting though kicks over fine. Put new plug in and no change. It is spark, not fuel, starting fluid has no effect. Is there a common spark fail item on MZs? A Module? Thanks in advance!
