No Spark
No Spark
Postby cmg241 » Wed Apr 13, 2016 8:31 am
Looking for other with similar problem = solution. Last early winter when I started my Baghira it got up to temp and started sputtering and died. Next day did same, since then not a hint of starting though kicks over fine. Put new plug in and no change. It is spark, not fuel, starting fluid has no effect. Is there a common spark fail item on MZs? A Module? Thanks in advance!
cmg241
Re: No Spark
Postby DAVID THOMPSON » Wed Apr 13, 2016 6:11 pm
check wires at coil mine just fell off one day
about a block from the house.
got lucky and spotted the problem befor a push to the house was necessary
Re: No Spark
Postby cmg241 » Sat Apr 16, 2016 12:17 pm
DAVID THOMPSON wrote:check wires at coil mine just fell off one day
Hey Dave thanks for your help - It runs! :D Cant say it was the plug wire, I went around checking all connections and it runs now. The fans arent coming on but that I will figure out. Now time to resolve master cylinder issue - I have looked and wow it seems like a common problem on these bikes. I changed pads and it wont pump up. I bled top to bottom then bottom to top.
Thank again
cmg241
