660 Scorpion cam chain tension
I can't find a reference on the net to doing the cam tension, is it an automatic one (read somewhere its spring loaded) or is there a sequence to tension it?
I'm working my way through servicing it, need to change oil, coolant and check valve clearances too but these are covered in the MZ660 and SZR660 manuals I down loaded from the net.
