Skorpion Sport Silencer
Postby lavrentyuk » Sun Jun 14, 2015 4:57 pm
Is anybody out there still selling an alternative to the standard silencer ?
Regards,
Richard.
Richard Marshall
Wales, U.K.
lavrentyuk
Re: Skorpion Sport Silencer
Postby edfmaniac » Sun Jun 14, 2015 8:37 pm
I seriously doubt there is a bolt on option. If you want to do some basic fabricating on a new pipe mount, you can use an aftermarket silencer and mid pipe that will slide over your existing header. I put an FMF unit for an XR650R on my Traveller, then later added the racing header that is made for Skorpions by Projection Components. Sounded pretty nice after that but nothing compared to what it sounds like after the internal engine work. :D
Postby lavrentyuk » Mon Jun 15, 2015 2:01 am
Sorry, should have added that I am in the U.K.
Since when I have added a signature.
Richard
Richard Marshall
Wales, U.K.
lavrentyuk
Postby edfmaniac » Tue Jun 16, 2015 2:37 pm
These guys are in the UK and could probably tell you which can will work with their header, but I'm not sure if you are in the market to spend that much.
http://www.projection-components.co.uk/ ... -210-p.asp
And here's the thread where I rigged up the Pro Circuit T4 for the XR650, not the FMF for the XR650R. My memory is going fast. :?
viewtopic.php?f=3&t=5477&p=27985&sid=7b2f8d8b001f18a3893733198ea2c8d7#p27985
Postby tigcraft » Tue Jun 16, 2015 5:05 pm
I've one of those headers but I've never good round to using it. They were designed and fitted round my actual bike strangely enough but it's still not fitted. The build quality is top!
tigcraft
Postby Ferd » Wed Aug 19, 2015 12:04 am
I believe Ducati Monster 750 exhaust cans were a direct bolt on..
I have a set from a 620 monster sitting in the garage I can measure for you if you want. I should do that just for my own knowledge..
Ferd
Postby lavrentyuk » Wed Aug 19, 2015 8:26 am
Thank you, that would be much appreciated.
Richard
Richard Marshall
Wales, U.K.
lavrentyuk
