fuel consumption on mz 660
Postby Dewald Malan » Sun Feb 01, 2015 12:11 pm
I just got a mz 660 and it seems to be running a bit rich on fuel im only getting 14km per 1l. does anyone have any advise on what i should do to improve this.
Thanks a lot Dewald Malan
Dewald Malan
Re: fuel consumption on mz 660
Postby DAVID THOMPSON » Sun Feb 01, 2015 1:18 pm
mine has always been hard on a tank of fuel
but have not had time to sort out why!!
Postby breakwellmz » Sun Feb 01, 2015 1:44 pm
That`s about 40 mpg(Uk) by my reckoning.
Postby Dewald Malan » Sun Feb 01, 2015 1:58 pm
I have a aftermarket exhaust on. should there be any setting done to the carb because it does smell a bit rich as if its running very heavy on fuel. I have had a look on the reviews and specs and i should be getting 17 km per L. how many km do you guys get on a L
Dewald Malan
Postby DAVID THOMPSON » Sun Feb 01, 2015 9:57 pm
mine goes about 95 miles and needs a fill up so i am thinking about 35 mpg in USA gallons
at 115 miles mine becomes a pusher but i am getting to old to push it..
do not forget to put tank lever back in the run position after fillup
so you do not run out and discover you have no reserve
its a pain parkersburg wv to clarksburg wv at night requires you carry 2 gallons in the
buddy box taking up space you need for other stuff because of a lack of open service stations
Postby Dewald Malan » Mon Feb 02, 2015 1:46 am
thanks a lot for the help and reply.
Dewald Malan
Postby breakwellmz » Mon Feb 02, 2015 3:45 am
Dewald Malan wrote:I have a aftermarket exhaust on. should there be any setting done to the carb because it does smell a bit rich as if its running very heavy on fuel. I have had a look on the reviews and specs and i should be getting 17 km per L. how many km do you guys get on a L
Have you checked that your choke is not sticking in the on position? Is it likely that someone has been inside the carb and maybe overcompensated for the freer flowing exhaust by going up too many sizes on jets, what is the sparkplug colour like?
Postby arry_b » Mon Feb 02, 2015 5:27 am
It should get a lot better than that. My Skorpion is more economical than my ETZ150!
My Traveller has never got below 150 miles from full to reserve even when riding enthusiastically. I have got 200 miles on occasion on tour before hitting reserve.
arry_b
Postby jaywillie2912 » Tue Feb 03, 2015 9:04 pm
Rode my Baghira from Orlando to Tampa to Orlando.....mileage of 51 mpg with a gearing of 15/43 riding between 70 & 80 mph maybe.
Hope this helps.
jaywillie2912
Postby clem27 » Wed Feb 04, 2015 8:22 am
I generally get to 180 miles before I have to switch to reserve. I have the single carb conversion but I am not sure of the sprocket size. I did go up a size in tires but my speedometer seems fairly accurate. Tachometer is dead though.
clem27
Postby Dewald Malan » Fri Feb 06, 2015 2:23 am
Thank you very much for the reply :D I havent checked the sparkplug yet. Me and my brother-inlaw are busy setting the carb. Could it be that the fueling screw on the carb is open to much?
Dewald Malan
Postby Dewald Malan » Fri Feb 06, 2015 2:25 am
arry_b wrote:It should get a lot better than that. My Skorpion is more economical than my ETZ150!
thanks for the reply im really happy to hear that its not normal for it to be so heavy on gas because im planning on touring trough the country of Lesotho with it.
Dewald Malan
Postby Dewald Malan » Fri Feb 06, 2015 2:26 am
jaywillie2912 wrote:Rode my Baghira from Orlando to Tampa to Orlando.....mileage of 51 mpg with a gearing of 15/43 riding between 70 & 80 mph maybe.
Hope this helps.
Dewald Malan
Postby Dewald Malan » Sun Feb 08, 2015 1:59 pm
what jets should i get for the bike will the raptor 660 main jet be okay. I live 1200m/ 4000feet above see level
Dewald Malan
Postby Dewald Malan » Mon Feb 09, 2015 1:43 am
:lol: :smt006
Dewald Malan
