where to find the correct alternator cover gasket?
Hi Guys;
I'm rebuilding my 660 traveler motor because of a loose timing chain. Got her all taken down and now beginning to assemble. I ordered what I thought was the correct gasket set and the head gasket and the cylinder gasket seem to be correct, as does the o ring at the base of the cylinder sleeve. The generator cover gasket is not correct...not far off but not correct. Can anyone tell me where to order the correct alternator cover gasket for a 2001 skorpion? I also need the valve cover gasket...nothing in the kit for that. I'm sure that I ordered a gasket set for a Raptor thinking it was the same. Also, does anyone know where I can get a workshop manual for the Skorpion? Thank you very much for the help.
Joe Everly
Joe Everly
