Skorpion ignition switch
Postby billr » Fri Sep 12, 2014 3:20 pm
Has anyone replaced the electrical part of the switch?
Reason:
Lost power Wednesday. It started with the intermittent contact with handlebar movement.
Checking the wiring and found a broken solder connection in the ignition switch.
Fixed that and moved the wires around for a bit more slack...all good for now.
Knowing how things go...
Is there anything that can be subbed...
I e-mailed Grahams for a price quote.
Bill R
billr
Re: Skorpion ignition switch
Postby DAVID THOMPSON » Fri Sep 12, 2014 4:08 pm
look at link for a list of bikes that use the same keys may be same lock set
moto guzzi comes to mind as well as some HD
a local breaker may have one
viewtopic.php?f=3&t=2596&p=14824&hilit=keyskeys#p14824
keyskeys in the site search box
if you take it all off be careful to locktite the bolts so it does not fall apart and wreck you
Postby billr » Fri Sep 12, 2014 7:29 pm
Thanks Dave.
I knew it was in here somewhere.
Will check with the local junkers to see what is out there.
Good reminder on the lock-set bolts. They are tight, I gave 'em a good twist while I was in there.
If I can just get the electric switch, that's just 2 Philips screws.
Bill R
billr
Postby DAVID THOMPSON » Fri Sep 12, 2014 7:46 pm
not many scrappers up my way any more
a good place to start may be a guzzi dealers scrap tub/scrap frames
or ask scooter club member for who works on the yamaha zuma scooters
and a lot of harleys use these switches
but bikes with rotax 4 strokes are wired different because of the way the spark is shut off
HD MT 500 is one
Users browsing this forum: Bing [Bot] and 22 guests
