Baghira choke cable
Baghira choke cable
Postby duncmac » Tue Jun 10, 2014 3:22 pm
Couldnt start the bike this morning.
Cables loose at the carb end.
Any advice for how it works? Is there a nipple at the other end I can just screw back on?
Ta
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Re: Baghira choke cable
Postby DAVID THOMPSON » Tue Jun 10, 2014 5:08 pm
there is a nipple on the carb end of cable it came loose or pulled loose
see picture
control plus sign will make picture bigger in some browsers /control+
choke plunger.jpg (9.14 KiB) Viewed 2944 times
Postby duncmac » Wed Jun 11, 2014 10:56 am
Thanks David!
I'll take a look this evening, the Mrs it out so I'll get to spend some time with the bike !
duncmac
Postby duncmac » Sun Jun 15, 2014 4:00 pm
Cable snapped, just above the nipple.
Had a spare on the additional carb I bought a while back so just swapped them over.
The snap looks like it was due to corrosion in part, as the spring and back of the plunger had rust dust covering them.
Might be worth peeling back the rubber elbow and squirting in some ACF 50 for those with as yet unsnapped chokes!
Cable snapped by spring, replaced it with a spare from my other carb (love spares!)
Backed off the secondary carb opening by one turn while I had the tank off, see if that makes is smoother in traffic.
duncmac
