What was the difference between tour and replica
Postby Srinath » Mon Apr 14, 2014 8:20 am
What was the differences from the tour/cup one to the replica ?
Cool.
Srinath.
Srinath
Re: What was the difference between tour and replica
Postby droy » Mon Apr 14, 2014 8:14 pm
Major stuff
Front forks, wheels, exhaust, lower bodywork, rest subframe, no rear hugger
DOUG
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Postby Srinath » Tue Apr 15, 2014 7:23 am
And it made 2 more hp - was the cam different, carb ? compression ?
Cool.
Srinath.
Srinath
Postby droy » Tue Apr 15, 2014 8:14 am
The carbs and engine are the same (needed to pass emissions). Magazine write ups of the day claimed the exhaust made the 2 extra HP. I've never seen a dyno comparison.
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
Postby droy » Tue Apr 15, 2014 10:24 am
Also the front wheels have dual 280mm disks and use twin Brembo gold calipers. The rear caliper is the standard black Gimica but some have changed to the Brembo gold.
I have a spare set of the Replica wheels fitted to my Sport - rear (with carrier and sprocket) is direct fit and the fromt requires a siggle 320mm brembo disk and some shimming of the stock caliper and axle.
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
Postby Phil Krix » Tue Oct 14, 2014 3:08 am
rear shock also different, WP unit like front forks.
Krixos
Phil Krix
Postby droy » Tue Oct 14, 2014 7:53 am
Very true
And to keep this rolling:
Speedo face is black
kickstand lug/stand is reshaped (I have the MuZ design drawing for the lug - long story!)
Triple clamps
Rear sets
Wheel spray guard
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
Postby Phil Krix » Wed Oct 15, 2014 1:34 am
Yep good call on those. I always wondered about fitting a wheel hugger to the Replica, Are they effective?
Krixos
Phil Krix
Postby Phil Krix » Wed Oct 15, 2014 1:50 am
Dory, you might be able to help me as you seem to know your business - I remember someone had indicated on the forum here a source of (maybe alternate?) rear brake caliper piston seals. Any ideas asi have searched but just seem to find the reference.
Krixos
Phil Krix
Postby droy » Wed Oct 15, 2014 7:29 am
Phil,
I don't know of any seals for the rear but they must be out there. It might be easer to convert the rear to the Brembo - those seals are easy to find and the rear Brembo are cheap (used).
I have a factory hugger on my Sport - works well. No mounting lugs on the Replica swingarm but it would work otherwise.
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
Postby edfmaniac » Wed Oct 15, 2014 6:03 pm
Phil Krix wrote:Dory, you might be able to help me as you seem to know your business - I remember someone had indicated on the forum here a source of (maybe alternate?) rear brake caliper piston seals. Any ideas asi have searched but just seem to find the reference.
Grahams has a good selection of Skorpion parts. They had everything for my fork rebuild so they might have brake components. http://www.grahamsmotorcycles.com/2010% ... n_Menu.htm
Postby DAVID THOMPSON » Wed Oct 15, 2014 8:21 pm
check this link and read they may be the same or maybe not
viewtopic.php?f=4&t=1490&p=8374&hilit=goldwing+seals#p8374
Postby Phil Krix » Fri Oct 17, 2014 4:20 pm
Thansk for the feedback everyone- very helpful
Krixos
Phil Krix
