CL&ph added:portland Or lurker:FS 2skorps&spares 3500.usd
Postby stewsail » Wed Dec 18, 2013 3:25 pm
660cc owners
CL ad
http://portland.craigslist.org/grg/mcy/4247393786.html
email
s_legler@hotmail.com,,
will email photos on request
re: classified ad: 00' Tour & 99' Traveler +spares all $3600 Portland, Or
thanks again: headed for trade in to a dealer who ships MZ's internationally (but they will not be these prices :oops: )
please see ad in classified
http://www.mzriders.com/viewtopic.php?f=13&t=7245&p=37964#p37964
stew
stewsail
Re: CL&ph added:portland Or lurker:FS 2skorps&spares 3500.us
Postby stewsail » Fri Dec 20, 2013 12:06 am
Why isn't anyone asking what we are getting instead?
I worship our MZ's but safety dictates...
Guesses?
Bueler?
anyone?
stew
stewsail
Postby Srinath » Fri Dec 20, 2013 8:32 am
OK what are you getting ... so I can live vicariously through you ... :( :-D
Let me guess ...
BMW megolith ...
Cool.
Srinath.
Srinath
the replacements :portland Or lurker:FS 2skorps&spares 3500.
Postby stewsail » Fri Dec 20, 2013 1:04 pm
We may have stumbled on the new "MZ" ie.the up to date perfectly balanced simple single cylinder light but road worthy (no road sofas, "ST"anything's or ... Vetec complexity)
that are disappearing forever as "new on show room bikes" just as i watched the last leftover skorps disappear (with little regard at the time) at the ducati shop where i was salivating over new st4s's (a 99 ST$ in the end).
back to now: While shopping at a husky shop for a replacement 250 dual sport i notice in the back of the Brochure for the 2013 Terra, a second model named the Strata which in very small print stated: selectable ABS. what? really - meaning: i don't have to buy a ninja to get a small displacement price bike with ABS. (a decision fraught with not!) and selectable ABS, change to a high fender - do it all? i would never consider more than a rental of a "BMW cross country 650" but this bikes engine as a factory admitted tweaked but ride-able with light wheels started to sound like the elusive replica (and more).
any of you in agreement? see below
Unfortunately this bike has no factory or brand home? - BMW has since bought rotax -this was a Sachs design: BMW has sold husky to KTM who has pulled it out of Italy.
[i]if they are not gone now: they will be in weeks.
http://www.husqvarnamotorcycles.com.au/product.asp?pid=58&t=TR+650+Strada+ABS&cid=3
In terms of engine technology, the TR 650 Strada relies on the tried and tested basis of the G 650 GS by BMW Motorrad. However, this liquid-cooled single-cylinder power unit with two overhead camshafts and 652 cc was extensively modified and its performance significantly enhanced for use in the new Husqvarna model. It delivers 43 kW (58 hp) at 7,250 rpm, developing its maximum torque of 60 Nm at 5,750 rpm. A reduced power version for LAMS is on offer as an ex works option with 35 kW (48 hp) at 7,250 rpm and 54 Nm of torque at 5,750 rpm.
ABS Standard
To match the dynamic performance available, the brake system consists of a single Brembo brake disc at front and rear which offers supremely solid stopping power, enhanced with ABS, which is disengageable.
High Quality Chasis
The new Husqvarna TR650 Strada is able to rely on an agile chassis based on a split-backbone tubular steel frame with remove-able rear frame and front beam bolted to the engine. Front guidance and suspension duties are dealt with by a torsionally-stiff 46 millimetre upside-down telescopic fork. The rear wheel is controlled by a torsionally-stiff dual swing arm made of pentagonal steel tubing in conjunction with a centrally-mounted rear shock with progressive linkage. In keeping with its use on asphalted roads, the Husqvarna TR 650 Strada has cast wheels made of aluminium.
[/i]
stewsail
Postby DAVID THOMPSON » Fri Dec 20, 2013 9:50 pm
i saw one of these nice bike
but way to tall at the saddle to make me happy
time to rebuild my 1963 R50s
Postby stewsail » Sat Dec 21, 2013 12:47 am
yes seat height and handle bar changes will be required
some unit conversions missing
http://www.motorcyclenews.com/mcn/biker ... 0-1994-03/
Max power 48 bhp Rated output 43 kW (58 hp) at 7,250 rpm
Max torque 42 ft-lb Max. torque 60 Nm at 5,750 rpm
Weight 173 kg Unladen weight, road ready 186 kg
Seat height 785 mm Seat height, unladen 860 mm
Fuel capacity 18 litres Fuel Tank Capacity 14 l
Average fuel consumption 47 mpg Fuel consumption over 100 km at constant 90 km/h 3.2 l/ 100 km
Fuel consumption over 100 km at constant 120 km/h 4.35 l/ 100 km
Maximum speed 110mph 175 km/h
Tank range 124 miles
Engine size 660 cc Capacity 652 cc
Engine 5v dohc single Water cooled 4-stroke single-cylinder, DOHC, four valves
Gearbox 5 gears Constant mesh 5-speed
Frame Steel tube spine Steel bridge frame with bolt-on steel rear frame
Front suspension adjustment Preload, compression Sachs upside down fork, ø 48 mm
Rear suspension adjustment Preload [b]spring preload mechanically adjustable, rebound damping adjustable[/b]
Front brakes Single 316mm disc ø 300 mm, floating two caliper brake
Rear brake 240mm disc ø 240 mm, floating single caliper brake
Front tyre size 110/70 x 17in Tyres, Front 110/80 R 19
Rear tyre size 150/60 x 17in Tyres, Rear 140/80 R 17
vs
http://www.husqvarnamotorcycles.com.au/ ... +ABS&cid=3
stewsail
Bikes traded 2skorps in. Or lurker: spares FS
Postby stewsail » Sun Dec 22, 2013 11:38 pm
Bikes traded in : after long trailer "ride" and a hard goodbye to Natasha & Boris: see "for sale" for more info on bikes fs & on parts still available
(if an MZ dealer was still open...) a trs with MZ engine case covers would IMHO initially look like a new MZ Baghira Black Panther or?: looks and feels significantly lighter than my traveler: wife is flat footed on a stiff new bike: so trs actual final settled height 1.35 maybe 1.5 higher to "settled skorps".
thanks
stew
stewsail
