Skorpion front brake caliper replacement
Postby mforza » Wed Sep 25, 2013 4:42 pm
I know this was discussed here before, I just cant find it :D
Looking for brake caliper that will replace the original Grimeca without major mods. Still using the original wheels and forks.
I know that Bill J. was talking about that but like I said I cant find it.
Help me out here please :)
mforza
Re: Skorpion front brake caliper replacement
Postby edfmaniac » Wed Sep 25, 2013 8:16 pm
Pretty sure this is the one you want. It's known as the P4 30/34 40mm and is scarce, but you can find them. This isn't as cheap as I've seen them in the past and make sure you buy the one for the right hand side. http://ducati-gowanloch.com/catalog/bre ... -3088.html
Postby edfmaniac » Wed Sep 25, 2013 8:26 pm
For the record, I replaced my master cylinder before replacing the caliper and, outside of racing, I just can't see where you'd need more power or control than the Grimeca caliper provides with a good pump. Then again, maybe my 50k mi unit is just one of those lucky few that came from an exceptional batch.
Postby mforza » Wed Sep 25, 2013 11:52 pm
Thx for the info. My problem is that at this moment I do not have any caliper on the bike im working on :D
That's why im looking for replacement.
mforza
Postby harold » Thu Sep 26, 2013 5:08 am
edfmaniac,
What master cylinder did you buy, and will it also fit a Baggie? Did it work with the brake light switch?
harold
Postby pod35 » Thu Sep 26, 2013 9:20 am
I have just done this with the caliper and master cylinder from a Cagiva Mito. They are fairly common on uk ebay. The only snag is that the master cylinder for that bike doesn't have a mirror mount and the reservoir is remote. I used a bar end mirror and mounted the reservoir on the clip on clamp.
R reg Tour 99,500km and counting....... now in 99,500 bits and counting
pod35
Postby DAVID THOMPSON » Thu Sep 26, 2013 10:07 am
10.4620.95
front master cyl
http://www.yoyodyneti.com/Search.aspx?K ... 10.4620.95
ask the guys at yoyodyneti about the mirror mount and the need for a brake light switch
and they may all ready know what fits
Postby pod35 » Thu Sep 26, 2013 10:36 am
Sorry, missed the part about brake light switch. I went down to my local bike shop and they let me look through their parts bins. Found a Magura brake light switch which fits the Cagiva lever and the MuZ loom. I've seen lots of these on Ebay too for about £5. I'm happy to compromise on the mirror for the feel of the Brembo master cylinder.
pod35
Postby edfmaniac » Thu Sep 26, 2013 12:39 pm
This thread should be a helpful reference. I believe I ended up with the 11mm, which at first feels kinda mushy, but ended up being a very linear response with plenty of power for a rider of my skill level. viewtopic.php?f=3&t=5825&p=30000&hilit=brembo#p30000
Postby mforza » Thu Sep 26, 2013 10:27 pm
That topic is good :) thx to BJ for that write up on the calipers :)
I do not know what master I will use yet. I think anything I can find that have separate reservoir for better fit with clip ons.
On my race bike i had problem with it as the one piece master/reservoir will hit the bolts on the clip ons and I could not twist it lower for better position. Also I had to go to radial master for the same reason. Did not test it yet so will see :)
The brake power looks to be realy strong so I might have to go very light on it before I get used to it.
But that's just my race bike. For the street bike I might use something different unles I decide to put it on the race track also :)
will try to post some pictures later.
PS: For the race bike I just mounted Honda CBR radial master. Im using 2 discs but with the power that thing creates I think I might have overkilled it :-D
mforza
Postby Norman Wade » Sat Sep 28, 2013 7:21 am
I've fitted Brembo master cylinder and caliper to my Skorpion. Details here: http://youcanttouronasingle.blogspot.co.uk/2013/03/skorpion-front-brake-modification.html
Norman
Norman Wade
Postby systems » Mon Nov 04, 2013 5:36 pm
I have a 660 baggy 2001 and need to know how to find a rear brake caliper that works on that bike. The Grimeca caliper is shot so I need to replace it with one that works and fits in its place. Please advice
systems
Postby Old Dog » Mon Nov 04, 2013 6:26 pm
The easy answer to the question is to leave the master cylinder and change the caliper for one from a Cagiva Mito. Not expensive and you get nice feel and outstanding stopping.
Well that is what I have done, Brembo MC on the rear of course. Check out Bill J this is one of his things.
All the best
Old Dog
Old Dog
Postby Kcfirebolt » Tue Nov 12, 2013 4:42 pm
Hi everyone.
Norman Wade, based on your post via "touronasingle" , I've ordered a brembo front caliper (40mm between the mounting bolts)/master cylinder/lever/etc. from a Mito 125 in Europe. Thank you for the suggestion.
I fully acknowledge that I've bought these parts without asking some questions first, but here goes.
I intend to use this on my race bike. Are there any suggestions/thoughts/concerns about using this set up? Can anyone recommend pads for this setup? Is it a good set up for racing or are the performance gains limited over stock?
Any suggestions on race pads? I've used these in the stock bike based on a recommendation by Gordon Hamilton and love them: DP Brakes RDP Race Brake Pads.
Thanks guys.
Charles
PS. I'm looking for an aluminum rear subframe and race plastics if you have suggestions.
Kcfirebolt
