2002 Baghira No spark-need help
Postby lance_brum » Thu May 30, 2013 10:30 am
I have a 2002 Baghiraa 660 and I am having the same with no spark. I got this bike from a buddy of mine and he said that is ran one day and then the next he went out to start it and it didn't.
The neutral safety switch wasn't working, but I got it working now and the neautral light comes on and it cranks over like it was supposed to. It has strong compression when it cranks but doesn't have any spark. Where do I go from here? How of can I test and see if it is the coil, or CDI Box? I took the spade connectors off of the coil...shouldn't the red wire be getting some voltage when I press the starter button and turn it over?
Thanks,
Lance
lance_brum
Re: 2002 Baghira No spark-need help
Postby Sully5976 » Tue Aug 27, 2019 2:34 am
any joy on this mate as my bike is same
rode it yesterday, stopped a while wne to start and just turned, no spark
Sully5976
Postby Puffs » Tue Aug 27, 2019 3:55 am
Postby DAVID THOMPSON » Tue Aug 27, 2019 7:59 am
i had the power wire to coil.. fall off the coil on my traveller
the spade had lost its grip ..
Postby AIRMANBEAR » Tue May 26, 2020 11:27 am
DID YU EVER SOLD THAT PROBLEM ?? IT COULD BE THE PICK UP ON THE CRANK , THE CDI BOX , THE COIL...…….. YOU HAVE TO TEST EACH ONE .. AS I AM HAVING A SIMILAR PROBLEM... PUT A TIMING LIGHT ON THE SPARK PLUG WIRE AND SEE WHEN WHAT RPM..IT STARTS IF A T ALL?
AIRMANBEAR
