Screen for a Mastiff?
Postby daredevildave » Thu Jan 10, 2013 10:24 am
Any tips for a screen/cowling to fit a Mastiff would be welcome? I'm told a particular BMW item might do!
Also any info about a good quality, good value chain & sprocket kits and the same for replacement headlight bulbs (including suitable replacement headlight arrangement). Many thanks
daredevildave
Re: Screen for a Mastiff?
Postby daredevildave » Fri Feb 08, 2013 9:41 am
Thanks for that radiograf I'll have a closer look.
daredevildave
Postby Black Pussy » Mon Feb 11, 2013 3:14 am
Ive got a simson side predator on mine easy to fit and looks like a factory item.
http://www.simpson-detour.co.uk/Bikini% ... dator.page
Black Pussy
Postby DAVID THOMPSON » Mon Feb 11, 2013 9:23 am
if lamps of higher power than stock are installed ..
you may need to install a relay to protect the handle bar switch
or a relay that's already in the system but not able to handle the higher current needed
for 2 60 watt bulbs
Postby Baggy_Al » Mon Feb 11, 2013 1:17 pm
Side Predator, looks good but, how much :shock:
Al
2003 Baggy Black Panther.
Baggy_Al
Postby Black Pussy » Tue Feb 12, 2013 4:42 am
I bought mine off ebay second hand £50 and made my own brackets. I also got a carbon one for £60 off ebay for a bandit Ive sold. New its £200 for colours and £215 for carbon. Neil the guy that runs it is the most helpful guy around. Both mine had older lights and he replaced all four lights with newer models for £80 all in including postage, and repaired a scratch free. I will take a pic of mine later and post it for you to see. Cheers Mick.
Black Pussy
Postby Black Pussy » Tue Feb 12, 2013 4:44 am
Forgot to say I am converting to LEDs all round as the charge system can only cope with one dip or one main. Both at the same time is drain on the system. Mick
Black Pussy
