Hernz wrote:Thanks Doug! The locking washer is the final part needed.
I'm going to tackle the oil change tmrw but I have never done it on
A dry sump.
This is the procedure I've read online. Am I doing it right?
1. Run the bike to heat up oil
2. Drain oil from bottom via drain bolt (is there a secondary tube that needs draining?)
3. Replace oil filter cartridge after draining (right side of engine right?)
4. Fill underseat oil reservoir with 2 qts. Let motor run in order to fill crankcase with oil.
5. Top off with another .8 qts of oil
Very excited!
Hernz wrote:basser23 - Not sure what it's called exactly. But look at the right hand side of your bike - Behind the VIN stamp where the "Made in Germany" plate is- There is a bolt/nut set before and after "Made in Germany" . Those were missing. I only had 1 bolt near the "Made".
Good news - The sprocket nut finally came in today so The bike is pretty much done! Will post pix when it's light out.
Users browsing this forum: No registered users and 307 guests
