suspension settings
suspension settings
Postby bry_d » Wed Mar 30, 2005 4:26 pm
hello all i'm looking to have a muck about with the suspension settings on my black panther to get it to feel a bit more planted on the road . i was wondering what you guys have yours set at as mine is on standard settings and i think the front end seems a bit soft at the moment and the back is a bit vague
all ideas welcome
cheers
bry_d
Postby keithcross » Wed Mar 30, 2005 4:45 pm
Hi
I just wound the settings on the damping up 2 clcks all round. Seems to help.
You could wind the rear spring up a bit,but to change the front requires either a new spring ora spacerto increase the pre load.
Postby boysie » Fri Apr 01, 2005 4:07 pm
Well, I know it's out of character, but I wound the rear spring off slightly, then dropped the forks through the yokes about 12mm ( this requires spacers under the bar clamps) also remove a further 6mm from the preload spacers that reside under the springs, along with a good quality fork oil..
What this does in affect is not to make the bike softer, just make it ride a little lower [fine as ground clearance isn't an issue for road use] and speed up the steering slightly.
boysie
Postby andyw » Wed May 17, 2006 4:19 am
boysie wrote:Well, I know it's out of character, but I wound the rear spring off slightly, then dropped the forks through the yokes about 12mm ( this requires spacers under the bar clamps) also remove a further 6mm from the preload spacers that reside under the springs, along with a good quality fork oil..
I'd be interested in more info - what fork oil? - spacers for fork clamps??
2005 R1200GS - 2002 MZ Mastiff: No more :-(
http://www.MotorcycleInfo.co.uk
andyw
Postby BRAAAP ! » Wed May 17, 2006 2:50 pm
I would recommend making a note of the standard settings before you fiddle or you could really mess the handling up and not know what to set it back to. . .
or was that just me ?
:-D
two wheels good, four wheels bad. . . .
BRAAAP !
Postby andyw » Sun May 21, 2006 11:05 am
Yes, learnt that one the hard way :lol:
Bump..........anyone??!!
andyw
