clutch lever
clutch lever
Postby handsomejackuk » Mon Sep 17, 2012 10:48 am
just borrowed a cable oiler off my mate and the clutch does seem a little better..
also while i was at it i polished up the lever, and the master cylinder top as they were starting to look a bit manky
anyway i post a few pics of them later...off
back in the shed to polish some spokes.. and spray my clutch lever at engine side and the cable bracket.. then i polish all my engine casing bolts, rear wheel.... and then the front, and rear caliper to see to they need spraying was thinking of brembo gold..
what do you think ?
Re: clutch lever
Postby cat » Mon Sep 17, 2012 5:49 pm
Brembo Gold? really? Genuine? Brembo paint?
hmm
You're lucky the cable lube thing worked. I got one, years ago, tried a couple times, it just doesn't work, it sprays out - easier to drip drops of oil down the cable. It's the blue kind that...EMGO, i think, that all the bike shops have.
cat
Re: clutch lever
Postby handsomejackuk » Tue Sep 18, 2012 1:18 am
phew !!!!!
all front spokes polished... need to polish my rear spokes later.
or i may go to newport to visit clock man.!!!
as for cable oiler seems to be freer i give it a good try later i also took the lever off, and give it a good polish... the brake lever is a different story, as i drilled a hole innit
Users browsing this forum: No registered users and 75 guests
