liquid gold
liquid gold
Postby jim grace » Sun Mar 20, 2005 7:14 pm
:D Hi to all the gifted, Am going to service ( 4000 ) on the Baggey, couple of questions i would be gratefull of your commenta
1= what engine oil do you recomend, ie 10/40 semi or fully synthetic
2= tappets are checked cold ? what is the clearance.
3= do you wash the air filter and impregnate it with the apprpriate oil or substitute the air filter with ?
:P CHEERS JIM.
jim grace
Postby phlat65 » Mon Mar 21, 2005 9:53 pm
I use Pentosin 5w-40 synthetic, every 2500 miles.
the valve spec is on the sticker on the swing arm. set them cold..
I like the No Toil brand air filter oil, because it cleans up with soapy water. just a light coat from the outside if you don't do any off-road. and a thin coat of waterproof grease on the base area.
check the rear sprocket bolts every 200 miles or so, and replace the stock allen bolts with some hex head, and use blue locktight.
2001 MZ Black Panther
phlat65
Postby redhunter » Fri Apr 01, 2005 1:20 pm
I use Mobil 1 red cap (15/50) automotive because: http://www.xs11.com/stories/mcnoil94.htm
-Carl- :smt023
'00 MZ Skorpion Tour
'75 BMW R90S
'74 MG 850-T
'51 Ariel VH Red Hunter
redhunter
Users browsing this forum: Google [Bot] and 239 guests
