96 660 skorpion tour. tach not moving, Brake rotor warped
Postby turfsurfer » Sat Jul 28, 2012 11:00 am
Hey there guys, just picked up a skorpion for $400 because it would stall out after a few miles. Turned out to be a venting issue on the tank and only costed me one hour of labor to fix. SWEET bike I really like the feeling of one cylinder.
One problem with the bike is that the tachometer is not working, I will trace the wire, but I am looking for any info that the mz community can offer.
Problem two is that the front brake rotor feels like it is a little warped. I have looked for a replacement, but no luck. Do I have other options?
turfsurfer
Re: 96 660 skorpion tour. tach not moving, Brake rotor war
Postby droy » Sat Jul 28, 2012 6:38 pm
Sounds like a great deal!
its a Sport or early Tour the tach is a know issue - $$$$$ through MuZ. Some have replaced it with aftermarket or Yamaha tach. So have done a direct drive tach using a SRX drive off the side of the engine.
www.grahamsmotorcycles.com (UK) has a parts catolog on line.
The front rotor is also available from MuZ and EBC Europe has a rotor available. I've heard that US folks have ordered the rotor from US EBC distributers.
Have fun
Doug in NJ
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Postby Bill Jurgenson » Sat Jul 28, 2012 10:04 pm
forget the original tach.
there are lots of aftermarket instruments out there, some very good some pretty shoddy. Best bet for the money is a Scitscu
http://www.scitsu.co.uk/docs/fitment.htm
the third type down, coded red.
there are many others
Postby Skorpion » Sun Jul 29, 2012 3:33 am
turfsurfer wrote:Problem two is that the front brake rotor feels like it is a little warped. I have looked for a replacement, but no luck. Do I have other options?
Had that with mine, check to see the rotor is free to move on the bobins, I cured mine by one drop of oil on each bobin, be very careful you don't get any on the brake disc.
Good Luck.
Skorpion
Postby radiograf » Sun Jul 29, 2012 4:01 am
I use a little squirt of chain lube on the bobbins on a disc rotor. It goes on thin then thickens to coat the surface, and is designed so stick. Obviously wipe any excess of the disc before using.
radiograf
Postby Nils D » Sun Jul 29, 2012 10:37 am
Try to find a workshop that rebuilds instruments (I've found a few in Sweden, so I think you would be able as well.), and ask them to replace the electronics inside your tachometer (It's no use tying to repair the original electronics - I've tried.). I have no idea what it would cost, but then you can keep the the original dashboard, and dont have bother the hassle of fitting a new one.
Skorpion Traveller 96
Nils D
Postby turfsurfer » Mon Jul 30, 2012 4:26 pm
Thanks for the feed back fellas! I like the idea of keeping the original cluster, so I am going to try to find a place in san diego that rebuilds tachs, but I am not really in that much of a hurry because it is not completely necassary to ride it. I am going to give the bobbins a cleaning to see if it takes care of the braking issue.
Found a video on youtube about bobbin cleaning at http://www.youtube.com/watch?v=1qoPqN2GBdw.
This guys bike looks crazy with chains hanging off all over the place. Kinda wasteful and unnecessary, but who am I to judge?
I will post after I clean the bobbins
turfsurfer
Postby turfsurfer » Mon Jul 30, 2012 8:48 pm
cleaned the bobbins. They all moved freely before cleaning, maybe too freely, but they felt a little "gritty". After cleaning them the grabbyness was still there. It's not noticeable at high speeds, just at the last twenty feet or so before coming to a complete stop. looking for a rotor now, the tach will have to wait
turfsurfer
Postby radiograf » Tue Jul 31, 2012 2:14 am
Check the surface of the disc on both sides, there could be a pitted area, causing the brakes to grab. Could be that the rotor just needs skimming.
radiograf
Postby Skorpion » Tue Jul 31, 2012 3:06 am
Maybe your brake pads are glazed, I think I would give the rotor a sanding with wet & dry paper, and fit new HH sintered pads,
The new pads will not be a waste, as you will need new pads for the new disc if they don't cure the judder.
Skorpion
Postby turfsurfer » Thu Aug 02, 2012 12:56 pm
found some new pads on ebay. I think that I can see where the center disk is bent, it doesn't look like the rotor itself is bent. I ill try the new pads when they come. Found a new rotor for $275 + $35 shipping, but don't have the funds right now. Could there be any other disks that will fit?
Also, sinse I do not have a tach, at what speed do you shift to 2nd, 3rd, etc. I have always ridden inline 4 bikes
turfsurfer
Postby turfsurfer » Fri Aug 03, 2012 11:22 am
I'm thinking that it might be better to get a new wheel. I have an 01 yamaha r6 wheel lying around and also have a 91 suzuki gsx1100g with a bigger 18" wheel
turfsurfer
Postby turfsurfer » Fri Aug 03, 2012 4:01 pm
ok. I don't know if any one is reading still, but it seemed like the the suzuki wheel might have fit, if the axles were compatible. However, I was unable to get the axle to turn on the MZ. loosened everything, but no spinning. Started to strip the hex on the axle with a cheater bar, so I gave up and started to take a closer look at the bend in the inner ring of the rotor.
It seemed like the bend was restricting movement of the adjacent bobbin. I'm sure you guys are going to cringe, but I decided to hammer the sh!t out of it until it looked a little straighter.
Now the MZ is braking much smoother. Enough for me to say that I do not need a new rotor.
I would not recommend hammering the braking surface, but hitting the inner disk worked like a charm. SWEET
I love it when a hammer is the "right tool" for the job
turfsurfer
Postby radiograf » Sat Aug 04, 2012 2:46 am
You could do with getting that axle problem sorted, try gently heating the ends of the fork stantions with a paint stripper gun. The alloy will expand at a greater rate than the steel axle, loosening it up.
radiograf
Postby turfsurfer » Tue Aug 07, 2012 6:58 pm
thats a good idea. I will try it next time i am at my buddies house, he has a heat gun.
turfsurfer
