New inexpensive Slider Option - Baghira & Mastiff
Postby Meeners » Thu May 24, 2012 9:15 pm
So... I was looking for a cheap way to protect my water pump and cases... Let's see if you guys can put 2 and 2 together...
Fact: 1-1/8" = 1.125"
Lower bar on Baghira & Mastiff measures 1.119" diameter
Fat bar 1-1/8" risers for dirt bike... Mmmm hmmmmm
Good thing is ths bolt is replaceable in case it gets damaged in a crash...
Delrin sliders from whatever bike... I'm using ones from my girls yzf600r I'm selling...
Meeners | Street: 2003 MZ 660 'Baggy' Street Moto | Race: 1993 KTM 300 MXC SM
Meeners
Re: New inexpensive Slider Option - Baghira & Mastiff
Postby cat » Fri May 25, 2012 3:08 am
On impact, it will rotate around the frame tube until it hits the engine case, then - depending on where it is - it would protect the case.
Nice-looking digital Vernier, looks better than the standard cheapo digital one you see everywhere.
cat
Postby Meeners » Fri May 25, 2012 2:40 pm
I thought about running two clamps along one side and developing some sort of Steel Protector... but that might be a bit extensive. Plus if it did crash it would simply flip the bike when it hit the pavement.
You are right it probably will rotate. I'll post some pictures when the stuff get's here to see what it looks like...
Meeners
Postby Meeners » Tue May 29, 2012 11:19 pm
Here are some example pics guys... I've decided how I'm going to rock them but it's pretty versatile what you can do with them...
Meeners
