Valve stems
Valve stems
Postby RiverDrive » Tue May 15, 2012 12:54 pm
Can someone fill me in on the size valve stem I need for the Skorpion's rims? Are all valve stems the same size?
01 Sport Cup Gone Sport
RiverDrive
Bike Tire Valve stems
Postby jimc » Tue May 15, 2012 8:25 pm
As far as I know, tubeless bike valve stem (.327" diameter)is smaller diameter than car/truck stuff. (.453' or .625")
some different lengths and angles available if you look hard enough.
Most any bike dealer or bike parts/tires mailorder has the rubber pop in ones pretty cheaply.
Not a bad idea to replace with the tire.
The ultimate is the high pressure metal valve if you have a NAPA auto parts nearby.
http://napaonline.com/Catalog/Result.as ... 1&Dp=3&N=0
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Re: Valve stems
Postby cat » Wed May 16, 2012 4:20 am
The metal ones like NAPA has are what are typically used with tubeless conversions.
cat
