Done the Research; Posting my Found Info BAGHIRA & MASTIFF
Postby Meeners » Tue May 08, 2012 11:33 am
I have done a LOT of research on this forum, advriders, google, thumpertalk, etc to know everything i can about this awesome bike. I can't believe how much fun i've been having with this thing... but I know it could be even more fun after upgrading a couple things. I feel like I’ve done enough research to warrant asking for some help on a few things. So here goes! I will post up answers and information as I go.
Forks & Monoshock
From what I can find these are the 45mm Marzocchi Forks (Same as late 95-98 KTM). I have confirmed this is correct. I have also confirmed that a set of fork boots from a 1996 KTM 360 fits right up no problems
I've heard that people swap out the forks and triple trees for the YZ/WR forks... is there a specific year? Again, lots of threads mention it, but no pictures, and no specific information.
Front Brakes
I know there are hundreds of threads that discuss the p30/34 brembo caliper upgrades but most of them aren’t very clear if this is a bolt on affair on the BAGHIRA’s specifically. From what I understand there is a bit of issue with the spoked wheel and trying to clear it. There isn’t much discussion on if I need to purchase a new bracket or if I need to offset the front wheel at all. Can anyone clear this up? Can I just purchase the caliper and purchase a master cylinder later for the front? So far no answers
I've heard Beringer 4-pot Calipers will work, with a relatively easy stock steel home made bracket. But what bike manufacturer uses the beringer 4-pot? What modifications need done? Can you still use the stock Grimeca M/C with it? So far no answers
Here’s and example of the bracket for connecting to a Baghira: http://www.abload.de/img/100_01541d4x.jpg
Here’s an example of the P4 actually connected on a Baghira: http://img155.imageshack.us/img155/7194/imgp36265en.jpg
I've also heard of the Harrison 6-pot w/ the 6 seperate pads... I've spoken with a rep over there and they still sell the Baghi/Mastiff 6 pots.. They will want to confirm your bolt spacing and ensure fitment before purchase. Below is my email
RE: Caliper for 2003 MZ Baghira
mrbillet@mail.ndonet.com; on behalf of; mrbillet@billet.co.uk
Sent 22.5.12
Good morning Ameen,
Thank you for your email and image. Yes we still manufacture a 6 piston caliper to be a direct fit to the Mastiff. There was a cross over in years and to ensure we supply the correct fitment to you for your MZ Baghira, we would be grateful if you could advise us the distance between the mounting pitches and a photograph of the actual front end with the brake. The engineers can then cross reference the system and advise.
Yes we do ship to America.
prices are dependent upon finish and facia - for a MINI-6 BILLET ORIGINAL CALIPER WITH BILLET-6 FACIA SHOW POLISHED the price would be £284 plus shipment of £24.30 = £308.30 or Black Anodised or Clear Anodised £306.00 plus shipment = £330.30.
Our calipers are supplied complete, pads, pins, bolts etc and are a direct fitment to your stock front end.
I hope this is of assistance and await your advice.
yours
Janine
Harrison BILLET
Original Message:
Date: Mon, 21 May 2012 17:00:50 +0000
To: mrbillet@billet.co.uk
Subject: Caliper for 2003 MZ Baghira
Hello,
My name is Ameen, and I ride an MZ Baghira... (Same as Mastiff). I was wondering if you still make the 6-pot caliper that you used to make for the MZ brand that you once made at one time. I was interested in getting U.S.D. Price if I were to get this shipped here. Let me know!
[Description:
http://i49.photobucket.com/albums/f254/ ... ra%20Stree
t%20Moto/2012-05-19170801.jpg?t=1337485885]
A. Bakarè
Rear Brakes
Same for the rear… I’ve heard that I can upgrade to the p32f 2 piston caliper with ease and it’s a bolt on affair? Is this true for the BAGHIRA? I know this caliper looks like it’s used on most newer ducatis, aprilias, some KTM, and other bikes and can be found pretty easily in the US. I've never seen a picture with it on... at first glance, it looks like the inside pot casting will hit the spokes? No answers yet.
Frame Sliders and/or Case Savers (Protection)
Does anyone have any options for something to protect the cases? I’ve seen the stock cage that is made for the front and bottom of the frame but I have NO IDEA where I could get access to that. I have only seen pictures but have never seen any leads as to where I can purchase these.
Here’s an example: http://i922.photobucket.com/albums/ad70 ... aggy_b.jpg
Here’s another: http://i446.photobucket.com/albums/qq18 ... _FRONT.jpg
Do they have bolt on frame sliders I can bolt to the bottom run of the frame to protect my cases bottom of the motor?
Axle Sliders
I have read that for these we have to drill and tap the existing setup… Anyone have other alternatives, or possibly pictures of your setups?
Sprocket & Chain
There are some discrepancies on what the stock gear ratios on the Street Moto are. I’ve heard that the stock for the Street Moto was 15F and 45R, or 43R…. I am running 15/45 at the moment w/ a 112 link EK chain w/ a Screw Type Master Link. If you run 43 you can get away with 110, 47 you can do 116, and so on... I ran a 49 sprocket in the rear and honestly, it was too rev happy. IMO 45 is pretty nice... If you like to wheelie a lot in higher gears go 47.
Gas Mileage
I get from 31 to 45 mpg depending on how I ride w/ a 15/45 Sprocket setup. It's wierd because I get awesome gas mileage when I am doing the backroads romping on it... and if I'm just cruising around lugging it around I get a little crappier mileage!
Carburetion and Jetting
No information yet!
Helpful Links
Service and Factory Links
Factory Manual for Marzocchi Forks: http://www.teamslipstream.co.uk/pdf/Front%20Forks%20Manual.pdf
Factory Suspension Information: http://www.teamslipstream.co.uk/pdf/MZ%20Suspension%20info.pdf
Factory Parts Manual: http://www.teamslipstream.co.uk/pdf/mzdatafile.pdf
Factory Wiring Diagram: http://www.teamslipstream.co.uk/pdf/mzdatafile.pdf
Forum Links
MZ Riders Forum: http://www.mzriders.com
Aftermarket Parts Links
http://www.tunebike.de/
http://www.electrosport.com/site-map
Sump Guard: http://www.touratech-usa.com/Store/PN-040-1264/Sumpguard-MZ-Baghira-99-later
Sump Guard: http://www.off-the-road.de/Other-bikes/Engine-protection/OTR-Sump-guard-MZ-Baghira-Mastiff.html
Articles, Reviews and Informational Links
Great Article on Going from a SB to a Baghira: http://www.bobpickett.co.uk/bkit/muzbaghira.htm
Random Informational Links & Data
Can rock the KTM 950SM Mirrors: http://www.advrider.com/forums/showthread.php?t=201354&page=5
Oil Filter Part Number: Yamaha part # 4X7-13440-90
The stock spacers are 32mm ID,38mm OD and 50mm long, the ones i made are +20mm
Fork Oil Seal same as KTM360EXC Part# nr.7528197: http://www.mzriders.com/viewtopic.php?f=3&t=2421&p=14043&hilit=preload#p14043
Springs and Using 15w Fork Oil: http://www.mzriders.com/viewtopic.php?f=3&t=2780&p=15845&hilit=preload#p15845
Sprockets same as XT660: http://www.mzriders.com/viewtopic.php?f=3&t=5344&hilit=sprocket
rear: 200U-520-xx 36-50 tooth (Yamaha XT 600 1987-2003, XTZ 660 1991-1998, TTR 600 2004)
front: 342U-520-xx 14-16 tooth (Yamaha XT 600 1987-2003, XTZ 660 1991-1998, SZR 660)
Brembo P30/34 Front Caliper Interchangeable?
Brembo P32f Rear Interchangeable?
Rotors are Same as YZF R1 or R6
Turn Signals are Same as Ducati 1000ds
YZ450 Forks and Yokes fit but the wheels don't fit: http://www.mzriders.com/viewtopic.php?f=3&t=2298&p=13323#p13323
Aprilia RS250 or R6 front end can be Swapped: http://www.mzriders.com/viewtopic.php?f=3&t=2322&p=13349#p13349
Brake Adapter (Ktm) to use: http://www.mzriders.com/viewtopic.php?f=3&t=315
Brake Banjo Rear: The rear brake light switch is the same as BMW F650 -93 to 97 -M10-1mm
Marzocchi Interchangeability (1995-1998 KTM): http://www.advrider.com/forums/showthread.php?t=554545
The most Baller Baghi EVER: http://www.motorcyclenews.com/MCN/News/newsresults/mcn/2007/May/may-1-to-may-6/may0207mzpicturegallery/
Baghira/Brembo Brake Interchangeability: http://w.mzriders.com/viewtopic.php?f=3&t=1523&start=0
The brake....yep....it´s an Brembo P4 4 caliper brake, a Nissin 5/8 pump (from a Suzi TL 1000 or Yamaha R1 from ´02 etc.), custom made caliper adapter based on the SPIEGLER adapter, different brake line and a BRAKING 320mm disk. I´ve changed the pads to something better, SBS pads, art. number 566RS. They do their job very well. Spiegler don´t built the adapter anymore, so they send me the plans of it and a other firm made it for me. You must set the front wheel for ca. 2mm to the right because the disk slides at the fork if you don´t do that.
More Sprocket Information:
Renthal sprockets http://www.renthal.com/
Other Yamahas, same sprockets:
front sprocket: Yamaha XT 600, XTZ 660, SZR 660, SRX 400.
rear sprocket : Yamaha XT 550, XT 600, XTZ 660, XV 250, XV 125.
And...
http://www.jtsprockets.com/52.0.html?&L ... id=2532&p=
JT Sprockets Catalogue
Yamaha XTZ660 Tenere 3YF 1991 to 1995
Front Sprocket: JTF577
Rear Sprocket: JTR857
Front sprocket available in: 14, 15, 16 teeth
Rear sprocket available in: 38, 39, 40, 41, 42, 43, 45, 46, 47 teeth
That's it for now! Sorry if it's a lot!!!!
Meeners
Meeners | Street: 2003 MZ 660 'Baggy' Street Moto | Race: 1993 KTM 300 MXC SM
Meeners
Re: Done the Research; Questions Upgrading the BAGHIRA & MAS
Postby basser23 » Tue May 08, 2012 12:13 pm
Try looking at the offtheroad.de site...tons of neat stuff for the Tenere(sorta the same)xtr660 for case savers etc...hope this helps
Postby rodge70 » Tue May 08, 2012 2:50 pm
hi,front forks for the height reduced have no adjustment,full height version will/should have a blue knob on top of each leg,one does rebound the other compression, i think thats what its called,not sure without looking.
as for the rest,sorry not much help though someone will point you eventualy
rodge70
Postby Meeners » Tue May 08, 2012 3:02 pm
basser23 wrote:Try looking at the offtheroad.de site...tons of neat stuff for the Tenere(sorta the same)xtr660 for case savers etc...hope this helps
Thanks! I found a bunch of bash guards that look like they will work! Thanks! Haven't seen that site :)
rodge70 wrote:hi,front forks for the height reduced have no adjustment,full height version will/should have a blue knob on top of each leg,one does rebound the other compression, i think thats what its called,not sure without looking.
Look like I have the full height version! Yep, one is compression and one is rebound... No wonder this thing is so high! Are these the Marzocchi's then, or the Paioli's? Thank you!!! It sounds like they are the Marzocchi's.
Meeners
Postby Meeners » Wed May 09, 2012 7:30 am
Hopefully I can put together a sticky information thread on these different categories with links to healthy threads. I'm still reading all I can... Any other input would be great guys. Thank you in advance.
Meeners
Postby Carrotr1 » Thu May 10, 2012 7:17 pm
What exhaust did you use?
Carrotr1
Postby Meeners » Thu May 10, 2012 8:17 pm
It's just a Gtyr Yamaha muffler welded on... It's louuuud! But it sounds awesome under load :)
Meeners
Postby edec » Fri May 11, 2012 10:54 am
Thank you Meeners for sharing with us!
Good luck, Ed
01 Baghira
99 Ducati SS750
edec
Postby cat » Sat May 12, 2012 5:03 am
Meeners wrote:That said… I’m looking for a set of Fork Boots to protect them. Anyone know where I could source some? I was going to see if I could just order some from an older Honda DR650L.
The problem with that is there is nowhere to attach the top of them - you'd have to use cable ties, and then they tend to slide down, or hose clamps. Better to use Seal Savers. I got some, I was just looking through my old order information folder but i can't find the order. I just remember there are two sizes/lengths - a short one that just covers the seals and a longer one that covers most of the stanchion tubes. Do a search - you'll find sealsavers.com and a bunch of threads on advrider.
cat
Re: Done the Research; Posting my Found Info BAGHIRA & MASTI
Postby Meeners » Wed May 23, 2012 12:46 pm
I ended up rocking the ktm360 fork boots and they fit :)
Here's a pic.
Also I updated the information in the first post.
Meeners
Postby cat » Thu May 24, 2012 2:19 am
:) Nice. How are they attached at the top?
Please tell more about the exhaust protector - and close-up pic when you can get to it. I guess your made it yourself, not from APA.
Good work for the compilation. Thanks.
cat
Postby pontala » Thu May 24, 2012 5:45 am
I have a queston on the battery it seams that the black wire is the positive wire and the light brown wire is the negative. Is that correct?
http://andyashton.com/mz/MZWiring.pdf
pontala
Postby cat » Thu May 24, 2012 6:25 am
Yes, brown is negative. I replaced mine with black and red. You can get flexible arc welding cable.
cat
Postby basser23 » Thu May 24, 2012 9:38 am
I just put red tape on the pos lead,black tape on neg side just to be sure :)
Postby Meeners » Thu May 24, 2012 9:58 am
cat wrote::) Nice. How are they attached at the top?
Just one zip tie on the fork tube right underneath the lower triple. I cleaned it all with alky right there and since its rubber it stays very well... no sliding at all! I'm really happy with them.
The Exhaust Slider is made from this really thick pipe they have at Lowes/Home-Depot. They also Have Pneumatic brake line you can use but they didn't have any. Anyway, the piece I used is really really hard and is two layers - has hard rubber on the inside and the harder polymer on the outside. I got the really nice 4" clamps and slid it through and that thing isn't going anywhere. Those $100 sliders are made of literally the same stuff, I can't believe the scam they are running. It cost me $8.00 total because I bought enough hose for two.
Meeners
