Sprockets and chains
Postby Kcfirebolt » Wed Mar 28, 2012 3:48 pm
Hi all. Long time lurker here in need of some help/direction/advice.
I race a Skorpion with AHRMA, and I need new front and rear sprockets.
I've talked with Galen Miller, and he recommends 15 front and 41 rear for most of the tracks that I'll be running this year (RA, Grattan, Barber, and Daytona).
Does any have a suggestion for where to find these? I'm struggling to find a source online. I also need a chain.
Are there other makes/models that use the same sprockets? For example, would a raptor front sprocket work? My bike is a 1996.
Thanks for your help.
Charles
Kcfirebolt
Re: Sprockets and chains
Postby Kcfirebolt » Wed Mar 28, 2012 4:05 pm
Found this. Is this accurate re. compatibility with xt600?
viewtopic.php?f=3&t=5344
Re: 47 T Sprocket in US?
by cat » Thu Oct 27, 2011 4:39 pm
Renthal sprockets http://www.renthal.com/
rear: 200U-520-xx 36-50 tooth
(Yamaha XT 600 1987-2003, XTZ 660 1991-1998, TTR 600 2004)
front: 342U-520-xx 14-16 tooth
(Yamaha XT 600 1987-2003, XTZ 660 1991-1998, SZR 660)
Kcfirebolt
Postby Kcfirebolt » Thu Mar 29, 2012 1:55 pm
<crickets chirping> :D
Kcfirebolt
Postby GordonH » Thu Mar 29, 2012 3:25 pm
Has Galen stopped selling chain and sprockets?
Gordon Hamilton
AHRMA #58r
GordonH
Postby basser23 » Thu Mar 29, 2012 9:30 pm
I just bought chain and sprockets 15/43 recently for mine...you can find DID ev2 520 just about anywhere I bought 114 links to be sure of length.
The rear 43 tooth I bought out of Texas,I'll look up where,and the counter shaft sprocket I ordered from my local yamaha dealer. I used a JT number for reference.
Look on their web site....for the Mz or SZR..
Chip
Postby cat » Fri Mar 30, 2012 2:11 am
JT website has diagrams showing dimensions, just a bit hard to find things there.
cat
Postby Kcfirebolt » Mon Apr 02, 2012 8:37 am
Thanks guys. I'll check the jt website. I'm grateful for the help.
Gordon, Good to hear from you. I expect every Michigan winter to be just like this one. Are you running RA and Grattan this year?
I've ordered a piston from Galen and a gasket kit. Tried to get sprockets and chains too, but he didn't seem enthusiastic about running down pricing for them, and I eventually gave up. I'll try to run it down a little further before I approach him again.
What gearing do you typically use?
Kcfirebolt
Postby GordonH » Mon Apr 02, 2012 12:07 pm
Hi Charles. No RA for me, but I am planning for Grattan. The way AHRMA is doing Barber this year, you have to compete on two different days to qualify, so that will be my two days. I also just read that they'll be limiting the racers to 700 entries per day and there will be a mandatory practice on either Friday or Thursday, or you can practice both days if you want. The drawback is there will be no practice on the race days in order to complete the race schedule. Should be interesting to say the least.
For gearing at Grattan I run 15 front and 41 rear. That lets me get a good run at the checker out of the last turn.
The sprockets I have came from Sprocket Specialties. I got them as part of a package when I bought a spare bike and I don't know if they were custom made or not. I can't find any listing on their website for the MZ. None of the Yamaha numbers match either. The number on the 41 tooth sprocket is 520Z. All the others, 43,42,39,38,37,and 36, have 187Z stamped on them. Maybe a call would sort things out.
You coming back to Flint? If you're there now, there is a school at Grattan this Saturday and an open practice for racers on Sunday. I'll be there Saturday helping out.
See you at Grattan in June?
Gordon Hamilton AHRMA #58r
GordonH
Postby Kcfirebolt » Mon Apr 02, 2012 4:42 pm
I'll be in Flint later this week, but I won't be able to get my act together by Saturday. I have my GSXR in Flint, so I'd like to come do a school with you. I need to work on some things. What other dates are you instructing? I need the help. How much are trackdays there?
Kcfirebolt
Postby GordonH » Mon Apr 02, 2012 6:18 pm
This is the only day that I instruct. If you already have your race license, I'll be at Grattan on the Friday before the AHRMA race weekend if you need help finding your way around the track. If you want, you can come to the track this Saturday and just check it out without riding. Entry is 5 or 10 bucks for the day.
Gordon
GordonH
Postby Kcfirebolt » Mon Apr 02, 2012 8:11 pm
Okay. I plan to be there Friday before Grattan for sure. Sorry to hear you won't be there before. I get back to Flint on Wed or Thursday. I'm not sure if I can make it out there Saturday or not, but I'll let you know. Thanks for the good counsel. I'll likely need to pick your brain some more before I get this thing sorted. Thanks again.
Kcfirebolt
Postby mincehead » Fri Apr 06, 2012 12:29 pm
Do you guys across the pond not have sprocket manufacturers that will work from patterns, even simple two dimensional drawings?
We have loads in the UK.
mincehead
Postby billr » Fri Apr 06, 2012 2:29 pm
mincehead wrote:Do you guys across the pond not have sprocket manufacturers that will work from patterns, even simple two dimensional drawings?
Yep, we got 'em.
Probably where I'll get the next set...since you can't walk into a shop, say "MZ Skorpion" and get anything other than blank looks...
Bill R
billr
Postby basser23 » Fri Apr 06, 2012 4:52 pm
Bill I found mine in Texas,for the front i just ordered from Yamaha dealer using JT numbers,
Rear was found like i said in Texas, Ill post the name when I get home tomorrow...
Ducati Paso 907 rear sprocket is same dimension and mounting :)
Postby chisleu » Fri Apr 06, 2012 7:29 pm
I got mine from http://off-the-road.de/ (the 50 or 51 tooth)
I got my "JT Sprockets JTR857.47 47T" from amazon.
chisleu
