rear brake light not working ?
Postby mr-brightside » Sat Mar 10, 2012 5:53 pm
my baghira just failed its mot on the rear stop light im asuming its just the brass nut switch is this a common thing that could go wrong or could it be anything else? do i have to get an original mz one or will any other models fit? , thanks in advance
mr-brightside
Re: rear brake light not working ?
Postby edec » Sat Mar 10, 2012 6:31 pm
Me too. Please keep us posted.
Thanks, Ed
01 Baghira
99 Ducati SS750
edec
Postby DAVID THOMPSON » Sat Mar 10, 2012 6:48 pm
bmw number for front
or aprilia number for rear
the front one is a bmw part
61 31 1 244 070
This FRONT part fits models listed for year 1981 maybe others
R80, R80ST, R65, R80RT, R80GS, R100/7, R100CS, R100RS, R100RT, R65LS
also fits 2002 mz rt125cc and 1995 saxon tour and harley davidson sprint from early 1970's
looking at my notes from past work on my bike
aprilia number on parts bag is 8124479
this is for rear of rt125 mz number= 4125045005
search word brakeswitch
Postby mr-brightside » Sat Mar 10, 2012 6:53 pm
ive got the part number for the baghira (4125045005) and i can probably get one from grahams as its only up the road from me but i was just wondering if there was a jap bike one that would fit as it would probably be half the price.
mr-brightside
Postby radiograf » Sun Mar 11, 2012 3:29 am
You don't state, but did you check the bulb? On the subject of brake switches, the front is also fitted to many of the twist and go scooters, and are a lot cheaper to buy than the bmw part. If the rear is a black plastic cylinder with two wires and a metal nut, then a Suzuki aftermarket one should fit. I suggest that you search on ebay for a switch and compare the pictures.
radiograf
Postby radiograf » Sun Mar 11, 2012 4:07 am
Having done a little more digging, the switch appears to be a hydraulic one, it looks the same as fitted to some BMWs pre 1980. However, can I suggest you remove it and take it to your local car accessories place as it looks very simular to one fitted to the Leyland Mini. Just be aware that the pitch of the tread may be different, so you do need to compare them before purchase.
radiograf
Postby Skorpion » Sun Mar 11, 2012 5:10 am
Its a
M10 x 1.00 Hydraulic Brake Switch
Try M&P, BMW or ebay.
Skorpion
Postby mr-brightside » Sun Mar 11, 2012 3:30 pm
Thanks for all the info i didnt realy want to take the old one of until i got a new one as i thought this could mean avoiding to have to bleed the brakes but i think i may of found one on ebay that looks similar, but i will go into grahams first to see how much the original ones are.
mr-brightside
Postby den » Mon Mar 12, 2012 4:51 am
Skorpion wrote:Its a
This is just an industry standard thing and can be found all over the automotive industry and is not a manufacture only part, I bought an aftermarket one from flea bay for my sons derbi senda,just a direct replacement .
i believe m10 is the diameter and 1.00 is the thread pitch , all you have to get right is the total length?as this may differ.
http://www.ebay.co.uk/itm/HYDRAULIC-BRA ... 5d329624a4
den
Postby mr-brightside » Tue Mar 13, 2012 2:40 pm
thanks all sorted now got one from grahams for £16.00 passed mot today :D
mr-brightside
Postby DAVID THOMPSON » Tue Mar 13, 2012 8:57 pm
let me know how long it lasts
i have blown 3 of them on the rt125 in 10 years
Postby Tigerboy » Wed Mar 14, 2012 12:08 am
Interesting, I was checking to see why neither my front or rear brakes light up the brake light and then I find this thread at the top of the 660cc discussion.
In my case, I detached the wires front and rear and in each case touching the leads together lights up the rear bulb so unfortunately it's not the cheap :idea:
So, I figure both front and rear brake switches have gone bad. What are the odds? When i press down each lever, the switch does not seem to close, so I guess I need new switches front and rear.
What can cause these things to go? They look like sealed units to me, no place for dirt to enter.
Anyway, this discussion seems to suggest the rear one I can get at any automotive shop, but the front one is a BMW part (and there is no BMW dealer around here). Any other alternatives for the front, which looks to me, to be a kind of twist-screw type.
Tigerboy
Postby samandkimberly » Wed Mar 14, 2012 8:07 am
Tigerboy - where are you located? There are lots of places on the web where you can buy the switch. I got mine at Capital Cycle:
http://www.tinyurl.com/MZfrontswitch
12 bucks, fast shipping in the US.
samandkimberly
Postby edec » Wed Mar 14, 2012 9:51 pm
Both of mine have been out for a while. If I wiggle the front brake wire just right, it goes on.
Good luck, Ed
01 Baghira
99 Ducati SS750
edec
Postby DAVID THOMPSON » Thu Mar 15, 2012 10:11 am
i think the rear goes out because there is too much pressure in the system
when you use it hard
i do use the front most but some time use the rear one very HARD
i changed mine from a pressure switch
to an old time one from the past ..
Users browsing this forum: No registered users and 111 guests
