Rev Counter
Rev Counter
Postby Baggy_Al » Sat Feb 18, 2012 8:33 am
I would like to fit a small rev counter to my Baghira, has anybody on here done this? Is it easy? what parts are needed etc?,
Regards, Al.
2003 Baggy Black Panther.
Baggy_Al
Re: Rev Counter
Postby rodge70 » Sat Feb 18, 2012 9:02 am
trailtech/acewell would be the easy way but i think the drive is on the engine and blanked off,you would need the bits from i think a yammy,think i have seen this mod on this site somewhere,have a dig round
rodge70
Re: Rev Counter
Postby edfmaniac » Sat Feb 18, 2012 9:36 am
I have a Trailtech Vapor on my Skorpion but I only use the speedo and trip meters. The tachometer wasn't working for me and I don't really feel the need to monitor water temp at the moment. I tried wrapping the rpm sensor around the spark plug wire, as instructed, and never got consistent readings. I also tried attaching it directly to the coil and the rpms still wandered too much to be useful. After speaking with one of the local shop guys, he got his to work on an XR650 but only after contacting Trailtech and having them ship him a special sensor wire with a resistor or something soldered into it.
Re: Rev Counter
Postby Baggy_Al » Sat Feb 18, 2012 12:34 pm
I did not really want to fit a multi function unit, cost, functions I don`t need etc, I was thinking of a stand alone rev counter or possibly swopping the whole h/light speedo unit for a mastiff set up as there is one on ebay at the moment, although I would still need the engine drive bits you mentioned Rodge.
Al.
Baggy_Al
Re: Rev Counter
Postby rodge70 » Sat Feb 18, 2012 2:43 pm
sure i have seen a pic on here with the drive fitted,as for erratic rev counter on trailtech get the raptor resistor wire and that sorts it. :D
rodge70
Re: Rev Counter
Postby edfmaniac » Sat Feb 18, 2012 4:41 pm
Baggy_Al wrote:I did not really want to fit a multi function unit, cost, functions I don`t need etc, I was thinking of a stand alone rev counter or possibly swopping the whole h/light speedo unit for a mastiff set up as there is one on ebay at the moment, although I would still need the engine drive bits you mentioned Rodge.
Al.
They offer function specific units too that are very compact.
Re: Rev Counter
Postby edfmaniac » Sat Feb 18, 2012 4:42 pm
rodge70 wrote:sure i have seen a pic on here with the drive fitted,as for erratic rev counter on trailtech get the raptor resistor wire and that sorts it. :D
Thanks, I just found a post on the Raptor forums about it. Easy DIY fix.
Re: Rev Counter
Postby kendo » Sun Feb 19, 2012 5:47 am
I fitted an electronic one from M+P (£30) to my top yolk ,simple three wire install.
Kendo
kendo
Re: Rev Counter
Postby den » Sun Feb 19, 2012 7:41 am
I did it with a mechanical drive from an xt600 and a mechanical clock with a 4/1 ratio from flebay
look at my gallery photos,have fun with the tacho cable though,
den
Re: Rev Counter
Postby Baggy_Al » Sun Feb 19, 2012 12:58 pm
Thanks guys, a few options to consider.
Al.
Baggy_Al
Re: Rev Counter
Postby basser23 » Wed Feb 22, 2012 1:08 pm
Those using the TrialTech Vapor need to have a 600k ohm1/4 watt resistor inline from the coil to tach. that is their "special" wire...
Re: Rev Counter
Postby nopantsflyer » Fri Feb 24, 2012 6:20 pm
i mounted an acewell tach, there is a free plug on the CDI, if you plug it in you get a steady reading
nopantsflyer
Re: Rev Counter
Postby Bill Jurgenson » Sat Feb 25, 2012 4:50 am
nearly all aftermarket tachs can and should be connected directly to the minus pin of the coil. Of course thay can be connected to that terminal of the ignition box (which is not a CDI) but not to any such thing as a "free pin."
Acewells are such tachs. So is the Scitsu (or can be; there are several versions) which is by far the best buy for the money.
The original large Skorpion tach has the same signal.
If you have a box with blue label, then any such tach will work.
If you have the orange label, the tach has its own plus signal which is a separate pin on the box.
Users browsing this forum: Bing [Bot] and 13 guests
