oil overflows
oil overflows
Postby chisleu » Sun Jan 08, 2012 11:32 am
After riding the bike, I let it idle for 30 seconds and turn it off to let it cool down for 30 seconds, all while keeping it upright. Then I check the oil.
The last 2 times I tried to check the oil, the oil started leaking out of the hole.
Is it just overfull? I didn't expect it to happen the second time. I'm going to ride today and see what happens after unless someone has some input.
chisleu
Re: oil overflows
Postby jimc » Mon Jan 09, 2012 6:08 pm
Assuming you're checking at the dipstick /filler location, if it overflows you're 'way over full.
I'd say you need to sniff check for gasoline in the oil - most likely reason for rising level.
If so, drain that oil & refill to proper level.
Check for goobered up float needle leakage. Turn the petcock off when it's parked.
Good Luck,
Jim
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Re: oil overflows
Postby chisleu » Mon Jan 09, 2012 7:43 pm
jimc wrote:Assuming you're checking at the dipstick /filler location, if it overflows you're 'way over full.
Good Luck,
Jim
I'll check for fuel in the oil, but I just ran through the carbs twice. I was rereading the oil change info and it occurs to me that I didn't warm the bike up before I drained it (although I did crank it and purge the oil filter area of air after I filled it the first time.)
I'm hoping it's just over full. I'm going to try to check the level with the bike cold so I can at least clean it without the pipes being hot.
chisleu
Re: oil overflows
Postby iceman » Mon Jan 09, 2012 8:32 pm
John Lennon
iceman
Re: oil overflows
Postby chisleu » Mon Jan 09, 2012 9:26 pm
I believe I am missing one seal from the course oil screw. There is always a drip of oil on that screw.
chisleu
Users browsing this forum: No registered users and 151 guests
