Carb swap with XT660
Postby paul599 » Fri Jan 06, 2012 6:18 am
Hello,
I seem to have some carb problems with my Baggi, running rich. I've had the bike on a dyno and the carbs have been stripped and cleaned. The person that did it said there was wear on the slider and jets so would need some parts replacing.
I do have a carb from an XT660, I was thinking of puttting this staright on the Baggi. It looks like it might go straight on.
Can anyone tell me if this a straight swap or has anyone done this before?
paul599
Re: Carb swap with XT660
Postby basser23 » Fri Jan 06, 2012 12:16 pm
I think thery are the same...look up a parts fische for yammi parts to be sure..Are you talking about the left carb or the cv carb?
Postby Bill Jurgenson » Mon Jan 09, 2012 1:48 am
the XT660 has a single 40mm CV carb
you mean the XTZ660 and of course it has the same carb; it is the same engine.
