Carb Breather hoses
Carb Breather hoses
Postby Stuart109 » Sun Dec 18, 2011 4:57 pm
Hi
I am just putting my Baggy back together but can’t figure out the carb breather hoses.
There are two with a T piece in the middle.
One end goes out the bottom by the swinging arm with a pile of other hoses.
They connect at the carb to a vent between the carbs and a similar one on the right of the carb when viewed from the front, I marked these two.
But where does the third opening connect? Seemed so obvious when it took it apart, but now cannot find anything to connect to.
Can anyone help?
Stuart
Stuart109
Re: Carb Breather hoses
Postby Baggy_Al » Sun Dec 18, 2011 6:12 pm
try the vac hose thread,(7 threads below this) there are some diagrams that have been posted, or have a look on grahams m/cycles page -parts section. if thats no help I can have a look at mine on friday in the daylight(no power in garage).
Al.
2003 Baggy Black Panther.
Baggy_Al
Postby OLDMTNCARVER » Mon Dec 19, 2011 11:39 am
Stuart,
This picture is of the hose fittings number 7 and number 9 on my Baghira's carb. Both extend down to the "Tee" (behind the starter) and then continue as hose line number 21.
OLDMTNCARVER
Postby OLDMTNCARVER » Mon Dec 19, 2011 11:49 am
Stuart,
This picture shows where hose line number 21 connects to. And as Al noted, look at the diagrams I posted earlier in the 660 forum tread that concerned vacuum lines.
Hope this helps...
OLDMTNCARVER
Users browsing this forum: Google [Bot] and 109 guests
