Mastiff/Baghira Rear caliper (Dont get me started!)
Postby Bodskis » Sun Sep 18, 2011 3:32 pm
Okay I've had enough, these Grimecas are far too troublesome to bleed.
The previous owner has blanked the bleed nipple off and I have to bleed thru the banjo bolt, is this common? Given that, is there any other cheap rear caliper off another bike? I am tired and broken after a day of bleeding brakes!
Bodskis
Re: Mastiff/Baghira Rear caliper (Dont get me started!)
Postby basser23 » Mon Sep 19, 2011 10:42 am
not common as i understand,i'd get another caliper with a bleed nipple....even a Grimcrappa...try a Duc rear brembo...
Postby rodge70 » Mon Sep 19, 2011 2:34 pm
you could take caliper to a decent engineering shop and have the bleed nipple reinstated probably,depends on why it was blanked off in the first place,good luck.
rodge70
Postby handsomejackuk » Mon Sep 19, 2011 4:00 pm
its the u-bend on the brake hose, i had to reverse bleed mine from the caliper end syringe on the bleed nippple sorted it...
Al...
Postby Bodskis » Wed Sep 21, 2011 4:07 am
Thanks for your help guys, I will try all suggestions. :D
Bodskis
Postby funmonkee » Wed Aug 22, 2012 12:42 pm
Which Ducati rar caliper is a bolt on replacement for the Mastiff?
Also interested in what year R6 caliper?
Cheers
funmonkee
