The thing makes metallic squeaking noises, the bike doesn't even have to be running. I can bounce on it and make it squeak.
It is the shock/linkage area, no where else. Does any one know what it could be ?
Thanks.
Cool.
Srinath.
Srinath wrote:Linegeist: Thanks for that link, phenomenal write up.
I guess I will suspend the bike from my frame and get on it one day asap. The bike got no center stand.
Oh, I also should find out if it is the SA or the shock linkage right, cos swingarm pivot can be greased without the whole rear end comming apart.
Thanks guys. And I sign off by saying "Cool", I've been doing it for years, not to say the problem is cool, its just a signature.
Cool.
Srinath.
Srinath wrote:The swingarm bolt can be lubed without taking the rear end apart - you remove the bolt, but push it out using a dummy bolt of the same size. That will hold everything in place while you look @ the bolt to see what the damage is.
Cool.
Srinath.
Srinath wrote:Dont the swingarm have needle bearings in the ends @ the pivot ?
That I thought was one of those that was needing lube ?
Cool.
Srinath.
