OEM Shock for a Sport or Sport Cup?
Postby Road Weazel » Wed Mar 24, 2010 4:46 pm
Is this the original shock or was it replaced? The rear seems to sit a little high, like maybe the shock is a little longer than stock (which would be a good thing)...
Thanx.
Weazel
Road Weazel
Re: OEM Shock for a Sport or Sport Cup?
Postby guitarzan » Wed Mar 24, 2010 7:51 pm
My 1995 Sport came OEM with a Bilstein. Your's doesn't look like a stock unit.
guitarzan
Postby Bill Jurgenson » Thu Mar 25, 2010 2:22 am
it is definitely NOT the OEM shock. Can't tell what make from the picture but be happy you have a fully adjustible strut and not the stock Bilstein which is no great shakes if you only ride solo. And it tends to selfdestruct as many can testify over here.
Postby Road Weazel » Thu Mar 25, 2010 2:51 am
I figured it was probably off a 600 sportbike of some sort. The back of the bike seems to sit high, the sidestand is a bit short and the rake angle of the forks is a degree or two steeper than the specs say it should be.
All of this suits me fine as I'm a heavier guy (about 205 #/93 Kilos) and the 4.2" of trail seemed a bit excessive.
Thanx.
Weazel
Road Weazel
